Old 08-25-2009, 02:22 PM   #1
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Sound proofing a generator box
I am working on mounting my generator under my bus. I have the frame work done and was wanting to know how others sound proofed them. Plus how and where to have venting so it don't get to hot. I was thinking that the door will have some venting in it and right under the generator some venting. Help me out....Thanks
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 08-26-2009, 09:16 AM   #2
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Re: Sound proofing a generator box
Well that guy.....went through a lot of work....I want to keep my generator in one piece...and I want to take it out when I'm not using the bus.. (I don't want it ripped off) How does the RV boys have there generator mounted?????
Old 08-28-2009, 09:23 PM   #3
Use the bolts, It will keep your Genny from bouncing around. You could do like they do for window screens. The bolt is attacked to a metal clip that twists into place over the frame of the genny and tightens down to hold it in place on one side, on the other you can have Permanently mounted clips that the frame slides under. You would only have to un-tighten two bolts to get the genny out.
Stereo sound system ??? swinada Conversion General Discussions 15 03-27-2018 10:50 AM
Sound of a Cummins 220 bansil Cummins Drivetrain 4 01-30-2013 08:40 PM
Future-proofing for solar and wind PDBreske Alternative Fuels | Electric, Propane, Wood Gasification, etc. 6 08-01-2012 09:24 PM
Sound deading product Stuff Conversion General Discussions 0 06-20-2010 01:38 PM
Surround Sound suzy_F_homemaker Conversion General Discussions 6 07-18-2006 07:21 PM
