Old 03-21-2005, 01:37 PM   #11
Steve's Avatar
I think that is the solution I have been looking for as well, guess I'll have to order online since there isn't an Ace around.
Old 03-21-2005, 02:04 PM   #12
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Steve-check around locally, I don't know what surrounds you, but I have seen similar ones in Mom & Pop hardware stores in my area.
I also know that Lowe's carries different ones in different locations. I have 3 Lowe's stores within a 75mile radius, and they cater to their surroundings. For example: I can't get 2x3 lumber in Greenville or New Bern, but I can get 'em all day long in Morehead City. All 3 carry different styles of garage door hardware.
Griff is offline   Reply With Quote
Old 03-21-2005, 02:48 PM   #13
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
slit doors - Transit busses?
I was looking at a GMC fishbowl transit bus the other day and wondering what sort of mechanism they use for accesing the bus from the outside. Since they cannot gain access from any other doors they must be able to get inside somehow. Also they have split doors like a school bus. I know they have different mechanisms but they may have a system that can be applied. Does anyone have any info or photo's (for those of us visual learners)? Thanks in advance. -Richard
captainkf is offline   Reply With Quote
Old 05-19-2005, 09:58 PM   #14
Griff's Avatar
Year: 1982
Chassis: IH S1723
Hey gang! Finally had another semi-successful go around with the camera and was able to post a couple of pics of my T-handle latch release.
It's not pretty, but it is VERY functional, fairly unobtrusive, and with the exception of the very bottom of the clevis, hardly noticeable from the outside. The door latches quite easily, but securely, and still opens all the way without obstruction. I did cut off some of the T-handle shaft to prevent getting snagged on it while entering & exiting.
You can see them with some descriptions in The White Elephant album here:
http://www.skoolie.net/gallery2/WhiteElephant
Pardon the mess, I'm still renovating. If anyone has any questions, or wants part numbers for the hardware used, just post & I'll pass 'em on.
Total cost for the set up was under $30.00.
Please let me know if this helps any of you that want a little more security.
P.S. I also posted a new diagram of the floorplan that is taking shape.
Old 05-20-2005, 10:32 AM   #15
Steve's Avatar
Fixed your link to point to the right place.
Seeing as I don't have that kind of latch on my door handle I can't use the same method but I can use the t-handle
I am going to mount the handle to the door as you have but with the bar going down to the floor or across to the other door (since my doors open in opposite directions. It will then fit through a hole or bracket in the floor or other door and secure it that way. It will be nice since everything will be on the door itself and I won't have anything stringing across the front of my bus.
Old 05-20-2005, 05:21 PM   #16
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Re: Door latch
Thanks for all the info. Such creative ideas, it's great.
I have decided to remove the stock split doors in favour of a solid wood door I built. In British Columbia a few weeks ago someone broke into my bus by prying the doors open (read bent to crap! ) and stole my $2500 mountain bike. So I removed the doors and created a new one.
Now it is very thick, solid and locked!
-Richard
Old 05-20-2005, 10:04 PM   #17
Griff's Avatar
Year: 1982
Chassis: IH S1723
Thank you Steve, sorry for the trouble.
Seeing as I don't have that kind of latch on my door handle I can't use the same method...
I agree, it's not very asthetic the way it is, but at least it's out of the way. Ultimately, if I ever get the time, I would like to drill a hole through the defroster riser and route it all behind the dash to where the only places it would be visible are from the door to the riser and from through the dash to the latch. At least, for now, I have better security than I did.
I guess I should also have mentioned that the clevis only rotates between 30 & 40 degrees to release the latch and does not interfere with the left door at all. I guess I also didn't realize your doors open in opposite directions, but in principle, the link between the doors should be strong enough to hold the doors closed if only one door is secured. I don't have any of this latch rigged to the left-hand door, and upon herking & jerking vigorously on the T-handle (with door latched), have not seen any potential for inadvertent door opening, so if you were to run latches to the top & bottom of the door the T-handle is mounted on, it should hold for both. you could use hot-rolled steel slats or some all-thread rod & clevises to go up & down into slots/holes in the floor & top framework.
Hey, if someone really WANTS to get into my bus, they can, but it will thwart the passing common thief.
I have also devised a fairly simple locking system for the rear door, but the camera wouldn't cooperate long enough to photodocument it. On the outside, when leaving the bus in a parking lot, etc., I can padlock it via a mounted a swivel padlock hasp like those found on the locks of box-bed semi's, and a hole I drilled into the handle. Inside is just a piece of 2x3 wood notched to fit on both sides of the hand guard, and notched & rounded to wedge securely against the handle. A quick-release clevis pin through the guard & board holds the 2x3 in position to prevent releasing via vibration.
Old 05-21-2005, 08:51 AM   #18
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
I am making my door work with a electric window motor from a car.. I have working on the bench. I hope to have it in the bus soon. On the door linkage under the bus I have a spring that will pull open the door. to close the door I used the window motor with a cable to pull the door closed. The cable is under the bus. you will not see any thing inside. (you could mount the motor right to the door linkageunder the bus to open and close the door but I wanted to keep the motor clean and dry) Inside the bus will be a open and close switch. (No more door handle) Out side of the bus is also a open and close swicth Plus a key swicth to shut of the power. Now the door is locked... If I have a power Trouble all I have to do is pull a pin on the cable under the bus to open the door. I also going to try to make this work with a remote. The window motor is very fast and it has more than enough power to keep the door closed.........It work and it's sweet.........
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 05-21-2005, 10:48 AM   #19
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
door
Kirbystud, it sounds like a very interesting solution. -Richard
Old 05-21-2005, 11:59 PM   #20
Griff's Avatar
Year: 1982
Chassis: IH S1723
I agree, sound nice, post some pics if ya can! I opted for the manual method 'cause I'm trying to get a way form powered devices where possible (K.I.S.S., less parts to fail)
I still think it's a great idea though and would love to see more on the development & implementation!
anyone use a ductless mini split? chev49 Conversion General Discussions 1 05-17-2012 09:38 AM
Split Wheel Rims... TygerCub Conversion General Discussions 3 06-13-2009 07:59 PM
old five lug 20" 2 piece split rims mrjr Titles, Insurance, Registration and Money Matters 1 09-18-2007 03:19 PM
split rim conversion mizer19 Conversion General Discussions 5 03-24-2007 04:43 PM
Split Rims vs Radials Steve Conversion General Discussions 2 01-15-2004 08:12 PM
