Old 11-19-2015, 10:02 AM   #1
Spray foam floor?
I'm planning on doing my walls and ceiling in closed cell spray foam. In a house application, spray foam is usually applied underneath the floor in the crawlspace. What I'm wondering about is if I can use it instead of foam boards on the floor.
Frame the floor, spray foam, put plywood subfloor down, then the top floor?
Tippyman is offline   Reply With Quote
Old 11-19-2015, 10:06 AM   #2
Engine: 190hp 5.9 Cummins
For walls and ceiling, spray foam is the best.
Don't use spray foam on the floor. No need.
Rigid Styrofoam (Blue or pink Stuff) is 30% cheaper and will do a better job on the floor.
Build the floor like Jake C did. Starts on page 2. Best method I have seen.
http://www.skoolie.net/forums/f11/pr...utus-5059.html
Old 11-19-2015, 10:21 AM   #3
OMGIBoughtABus's Avatar
Chassis: Saf-T-Liner
Engine: Cat 3208
Rated Cap: 84 px
There is closed cell foam designed to be poured if you decide to go that route on your floor. It's what they use for boat flotation and works well for insulation.
OMGIBoughtABus is offline   Reply With Quote
