Old 09-30-2014, 08:51 PM   #1
Spray Foam Question
Hello Everyone! Quick question about spray foam and thermal breaks. We will be strapping the walls with strips of 3/4" plywood for our thermal break per instructions of many posts on the forum. We will be having spray foam done soon. Do we strap the walls and ceiling first and have the foam built up to the level of the wood strips or do we spray foam first and have the foam built up to the level of the steel support beams in the bus?
Does my question make sense? I can take pics if it doesn't!
1992 Bluebird.
Thanks!
Jeremy
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 09-30-2014, 09:31 PM   #2
turf's Avatar
Re: Spray Foam Question
my bus had been previously done with spray foam. here is a picture of how the inside looks. the foam goes to the steel, boards attached to the same.
Turfmobile Build Thread
Old 09-30-2014, 09:56 PM   #3
r_w
You can do either way, but if it goes flush with your wood strips it can SQUEEK against your paneling.
My vote is to do it flush with hoops and then use a sound proofing (wool or cotton) in between the strips if you have the dough.
r_w is offline   Reply With Quote
Old 10-01-2014, 09:14 AM   #4
Chassis: B3800 Short bus
I attached 3/4" strips perpendicular to the bus ribs then spray foamed under the wood and over the ribs, then paneled over. No squeaks. If I were to do it again, I'd do the same thing, except I'd hire a pro spray foamer. It would have been around the same price, but it would have been less wasteful and tidier. Also, the stuff the pros use expands more than the kit stuff and thus would get between the wood strips and the metal roof better. That was quite a challenge
Old 10-01-2014, 10:29 AM   #5
r_w
Did you insulate INSIDE the ribs? Is that possible with spray foam?
Old 10-01-2014, 10:47 AM   #6
Nope, not possible unless you take the outside skin off. I insulated over the ribs. I would be surprised if insulating inside the ribs would actually do any good. Since they are directly connected to the outside metal they act as a thermal bridge from the bus skin to the inside. Foaming the hollow inside of the ribs would not stop heat/cold from travelling through the metal, around the insulation to the inside of the bus. Foaming OVER the ribs, on the other hand, does work. Put as much as you can over those things..
Studs in a house have a similar effect (thermal bridging), but we don't notice it as much since wood isn't as good of a conductor. Here are some thermal images of what I'm talking about.
Inside of house is warm, outside is cool:
Inside of house is cool, outside is warm:
Old 10-01-2014, 10:49 AM   #7
Thanks Jatzy. I think this is what I will do. It will give an extra 3/4" of insulation all around!
WVO Powered!
Old 10-28-2014, 08:43 PM   #8
We are dropping the bus off to get sprayed in two more days... I have another question. Does anyone know what kind of heat that spray foam can withstand? I was wondering if it would be possible to spray foam the inside of our engine hatch/lid on our FE TC2000? The foam noise/heat insulation thingy is falling apart. Figured spray foam could be a good replacement if it can withstand the heat. Anyone ever try this?
WVO Powered!
Old 10-28-2014, 09:34 PM   #9
I think you will get better sound protection with a dense material --like horse stall rubber mat. The foam stuff is real good at quieting high pitch noise, but the low pitch noise of a (diesel) bus is better quieted with very dense material--lead is best. Jack
Old 10-29-2014, 11:21 AM   #10
Thanks Jack!
WVO Powered!
(Spray) Paint Job. Pre/Post prep. bassbus Conversion Tutorials and How-to's 12 03-15-2013 01:46 AM
spray foam under floor - who has done it? ramairws601 Conversion General Discussions 6 10-16-2009 05:29 PM
staying cool - spray roof w/Ceramic heat resistant coating? nearhomeless Conversion General Discussions 1 06-10-2009 11:50 AM
Best spray gun for painting?? paul iossi Conversion General Discussions 2 05-15-2009 11:35 AM
Wagner spray painters and your bus Billsman Conversion General Discussions 5 05-06-2008 03:32 PM
