Old 01-09-2011, 10:13 AM   #1
Year: 93
Chassis: ?
Stabalizer location problem
Stabalizer placement.
Its time to stabalize this beast so folks inside the bus dont lose it because folks on top of the bus are getting carried away.
I have the front figured out(ends of c-channel behind bumper) The rear is another issue. In the picture below the black line represents one of the ribs that makes these buses like tanks. The blue and red lines are my crude drawing of a stabalizer jack or outrigger. The idea is to attach it via an 8" piece of flat strap bolting it(2x) thru the rib. This same rib is one of the bolted supports for the deck above thus directly connecting the deck to the ground.
This is not meant to lift....stabalize only. Other than being at the end of the rib with little sheet metal(relatively speaking) providing lateral reinforcement is there any reason this should not work. I could possibly reinforce the rib to the frame but it would encroach on future holding tank plans. There is really no good alternative to this placement because of all the other "enhancements" welded to this "enormous apparatus"
swhite832 is offline   Reply With Quote
Old 01-09-2011, 12:15 PM   #2
Year: 93
Chassis: ?
Re: Stabalizer location problem
That is an idea I will look at...there are some stoppers to it but work arounds may be available as well. what are your thoughts on the stability of the ribs.
S
Old 01-09-2011, 05:57 PM   #3
lornaschinske's Avatar
Rated Cap: 89
If all you are doing is stabilizing (not leveling)... how about truck camper jacks.
http://www.jcwhitney.com/cable-campe...terid=c21488j8
http://www.jcwhitney.com/olympian-te...id=c21488o20j8
Fulltime since 2006
Gas appliance location bluebird90 Heating, Cooling and Appliances 5 03-03-2013 11:27 PM
Thoughts on Generator Location? Diesel Dan Short-Bus Conversion Projects 6 04-25-2012 08:33 PM
AC unit location Diddly Conversion General Discussions 4 06-27-2011 11:14 AM
generator location putterspitt Electrical, Charging and Solar 13 12-10-2010 09:27 PM
Map location of people not working Stuff Forum Admin | Account Help | Suggestion Box 4 04-12-2010 11:28 PM
