Old 10-20-2008, 02:19 PM   #1
oldog12's Avatar
Re: Stainless steel sheet over windows
What gauge? If it's thin, you may consider getting a few beads run latitudinally to put some rigidity into them, but I guess it would look good enough...
oldog12 is offline   Reply With Quote
Old 10-20-2008, 05:50 PM   #2
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
4 guage difference from ss to mild steel 22ga ss =18ga mild just use a good drill bit and go slow if you do not have good hand held shears cut with a jig saw and a good blade slow and easy ss will look great! cuttin oil helps alot with the jig saw cuts timbuk
Sheet steel Zephod_beeblebrox2 Conversion General Discussions 19 12-31-2014 06:55 PM
Sheet metal over windows... staggerlee917 Conversion General Discussions 27 06-08-2009 02:22 PM
Looking for a good cheap source for stainless frank-id Everything Else | General Skoolie Discussions 5 03-29-2009 10:59 PM
Faux Stainless Steel-Look...Possible? ken worley Conversion General Discussions 2 07-31-2008 08:30 PM
Sheet metal guage for windows Billsman Conversion General Discussions 12 05-13-2008 04:39 PM
