Old 10-04-2015, 04:24 PM   #1
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Staying Warm with a Webasto?
The cold weather is setting in here in CO and I got to thinking about my heating needs. A wood stove is still in the plan, but I got to thinking about something for when I need heat faster or dont want to build a fire if im only going to be in the bus for a couple hours.
We have about 6 webasto thermo top c's ive been taking off buses that we sell, scrap, etc. and I got the idea to put one on my bus and plumb it in on a closed loop to heat coolant and run it through a pair of the underseat heaters i took out of this and another bus.
I would also pump the coolant through a flat plate heat exchanger to use for heating the tap water in my hot water tank if i needed/wanted hot water.
The unit puts out something like 17,000 btu and by circulating the coolant through the pair of heaters and running the fans, I hope to be able to keep the bus warm in almost any weather in this method so that I dont have to rely exclusively on building fires to stay warm. Also, the webasto can be controlled by a timer and I have an extra, 60 gallon diesel tank I can install under my bus just to supply the heater.
I am wondering if anyone has done something like this. It seems very promising and since I have them in abundance for free, it seems like an attractive option. I am wondering if I should add a tank in my coolant loop to store the heated coolant, but I think it would have to be quite large if I wanted to be able to cycle the webasto instead of running it whenver i needed heat.
Any thoughts or ideas? Anyone tried staying warm using a webasto?
Old 10-04-2015, 05:19 PM   #2
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
If you have any spares I'm all in for getting one!!!!!
M1031A1 is offline   Reply With Quote
Old 10-04-2015, 05:29 PM   #3
opus's Avatar
Chassis: All-American R/E
We use a Webasto all the time. Not the unit you are talking about, the DBW2010 is what I have. 45,000 BTU.
I left all my heaters in the bus, added a couple thermostats and a power supply to power it. All is right....
Old 10-04-2015, 05:34 PM   #4
charles_m's Avatar
Year: 1982
The units I have are all Thermo Top C's and have only 17k btus
Opus--Do you still circulate the coolant through the engine or have you looped it off? Is it your primary heat source? Any guess on fuel consumption in real life? Im really getting into this idea.
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 10-04-2015, 05:37 PM   #5
opus's Avatar
I circulate it through the engine. The engine is a huge heat sink, I dont know why people loop it off, that just makes the Webasto run more.
Primary heat source, yes. 0.35gph. Been overnight in -16 and survived nice and toasty.
Old 10-04-2015, 05:45 PM   #6
charles_m's Avatar
Year: 1982
I figured I'd rather loop it off and not try to heat a ton of steel that's not in my living space. I was toying with the idea of a tank of some kind to buffer the cycling of the webasto. my only worry at this point is the cost of heating using this unit. granted, i can use the off-road diesel for this tank, which is nice.
www.bustoshow.org
Old 10-04-2015, 05:48 PM   #7
opus's Avatar
My fuel comes out of my main tank. You already have a tank, the engine. Its thick, heavy and will hold hot water for a long time.
Old 10-04-2015, 05:52 PM   #8
Chassis: Blue Bird
Engine: ISC 8.3
In about January 2014 I did an experiment in my bus. I laid two electric baseboard heaters on the floor (4.5 kW total), wired them up to 240 through an electric meter, and let it run for the night with a few temperature loggers. The low that night was 16 F outdoors and the bus dropped to 58 F. That was measured in the center of the bus; the two ends probably were cooler because there was no forced circulation of the heat. This was bone stock; no windows deleted nor insulation added, though I note mine does have a layer of globbed-on foam insulation hanging like stalactites below the floor.. anyway, if you have added insulation and it doesn't get too much colder than this where you are, just the one 17 kBTU (about 5 kW) may get you through fine.
opus is right, the engine adds a huge amount of thermal mass and limits short-cycling of the coolant heater. But it's a huge radiator too, dissipating your heat to the outdoors.
It's in my plans to do something like what you describe. Since it (mine) will be gated off from the engine, it'll probably need its own coolant reservoir and expansion system. Nat described in The Four Season Prime, I think, an idea to have a stainless steel tank built with a regular radiator cap and expansion tank and other features too. My thoughts are headed in that direction as well.
Old 10-04-2015, 05:56 PM   #9
opus's Avatar
What I did to help [havent used them yet] was make a couple insulated panels to cover the perforated doors on the back of both sides of my bus. That surely should do something.
We needed the Webasto last weekend but we had shore power so I ran an oil filled radiator instead.
Old 10-04-2015, 06:00 PM   #10
charles_m's Avatar
Year: 1982
Yeah, at this point I'm kicking myself for not taking the time to figure this out and run some lines in the floor for heating the bus that way.
When I raised my roof, I removed all the bus windows and use only double-pane insulated rv windows. There's probably 1/3 of my wall area that is window now. The bus is insulated by an average of 2.75" of spray foam, and 3" of rigid foam (poly-iso) in the floor. Im at close to r-20 all around when you factor in the reflectix I put over the spray foam so hopefully, this should keep me toasty in the cold.
I just cant justify using the engine to store thermal energy. One idea I had was to use an old water heater tank and put it sideways under the bus. Not sure how many gallons I should do yet for that, but it seems like it would work. That would be a lot of coolant though...
www.bustoshow.org
Old 10-04-2015, 06:15 PM   #11
M1031A1's Avatar
Rated Cap: 87
So I take it y'all don't have any spares? I'm looking for a good used Webasto or comparable heater for Heavy to keep us warm in the winter. I figured if I begged someone would know where to find one (or two)....... I have some money, just not a whole bunch (unless you want to count the ones.......).
Old 10-04-2015, 09:28 PM   #12
Engine: 190hp 5.9 Cummins
Unless the engine is covered with spray foam, it will not act as a thermal mass storage. It will act as a thermal dump, wasting a ton of heat and more importantly wasting a ton of diesel and money.
If you want to store heat in a thermal mass to prevent short cycling, add a storage tank.
Old 10-04-2015, 09:52 PM   #13
charles_m's Avatar
Year: 1982
Maybe I should just foam in the whole engine then. Imagine that, almost a full ton of thermal mass to use for heating
I'll probably figure out a tank, then. It would be great to keep it inside the bus, but Im out of interior room for something so big. Nat--any guess what a good size would be? I was thinking in the 30 gallon range... bigger would be better but filling a 50gallon system with coolant seems like it would be $$$$
I entertained the idea of taking a steel box, putting a cooper coil through it, then filling with sand or some other heavy, dense material, then putting this box in an insulated, larger box. I would then only have to run the coolant through the copper tube and sand is way more dense for storing energy than water.
www.bustoshow.org
Old 10-04-2015, 10:03 PM   #14
opus's Avatar
I'm working on a couple but sadly you'll need more money then you want to give.
Old 10-04-2015, 10:10 PM   #15
opus's Avatar
Thats not exactly a true statement. In this case however, a water tank would be far more efficient. If you have the space you want to give up that is.
I use my bus every other weekend for 3 days. If you were living it it, sure enough, foam everything...until you need it to be cool in the summer.
Any heat loss from my engine goes up...right to where our bed is. Its a win win for me.
Sure, its not the most efficient way to go about it but, I dont have to cold start my engine.
The less complex a setup is, the better.
A water heater tank would be the cats meow though if you were living in it.
Old 10-04-2015, 11:28 PM   #16
The beginning information needed to start this calculation.
Interesting way of thinking.
At the shop we do the foam side vent covers for lowering the amount of diesel used each night when the winter wind is really blowing. It's unreal how much more heat it takes on a windy night.
Old 10-04-2015, 11:37 PM   #17
opus's Avatar
We were out last year end of November. It was -8 and we couldn't get out of the wind. That was the only time we've been cold, and we were cold!
That's why I made foam vent covers last week.
Old 12-14-2015, 03:31 AM   #18
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
I was recently looking at Webasto duo-top evo, so if you have something similar available I'd be interested. I don't know how the boiler system would work for "on demand" or if that's even possible. 12L doesn't seem to be a whole lot of hot water.
I also plan on going with as many diesel-operated systems as possible. I plan on adding an additional 50gal diesel tank to support those systems.
My project: The Cruel Bus
RHOMBUS is offline   Reply With Quote
Old 12-14-2015, 06:11 AM   #19
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
have you considered a small lp on demand unit like an l5 with a dc circulator pump with either in floor heating or radiator type exchanger.
my build pics
Old 01-04-2018, 12:41 AM   #20
Heat with the coolant?
Are you heating with coolant, opus? How did you set it up to cycle through the bus?
bridgefamily is offline   Reply With Quote
