Old 02-19-2018, 08:42 PM   #1
Steel Frame Pre-treatment
So I will be starting my conversion soon I think and was wondering if you guys painted/primed/ rust treated the metal before adding in the extra insulation when removing the ceiling floor/walls on your bus?
Obviously I will fix any damage as needed but I have seen a few folks treat the inside before insulating and wondered with what?
I thought a good rust converter type product on the rust areas after being cleaned and some sort of primer for the rest?
PNWorBUST72 is offline   Reply With Quote
Old 02-19-2018, 08:46 PM   #2
Chassis: Saf-T-Liner MVP ER
After remediating rust (Ospho-based is best) and filling holes, Rustoleum Primer is the most common application before insulating and a new floor.
Steve Bracken
Build Thread
Old 02-19-2018, 08:57 PM   #3
So something like this after repairs and light rust removal using a garden sprayer:
https://www.amazon.com/dp/B003Q7XWU4...BGDAS6YV&psc=0
And then this to seal it all applied with a cheap paint sprayer?
https://www.amazon.com/RUST-OLEUM-77...stoleum+primer
Old 02-19-2018, 09:01 PM   #4
I'd use a wire-brush or flap-wheel in a grinder to get the loose stuff off, but yeah.
... and I'd probably roll it on
Steve Bracken
Build Thread
Old 02-19-2018, 09:24 PM   #5
Yeah I figured I would need to run over the rust with a wire brush/wheel first.
Roll on the primer or the converter?
Old 02-19-2018, 09:28 PM   #6
I wouldn't use a sprayer inside. Despite your best efforts the mist would cover everything, so roll on the primer.
With the Ospho, I'd use a large brush because it's easier to make sure it penetrates the tougher areas.
Steve Bracken
Build Thread
Old 02-20-2018, 07:12 AM   #7
Awesome, thanks!
Old 02-20-2018, 07:25 AM   #8
brokedown's Avatar
I used a big green scrub brush to apply ospho, then I rolled on primer after it had dried. For the inside of wall and ceiling I'm planning to spray rustoleum rattle can to get a light coat before putting anything against them. Still determining which adhesive to use for attaching rigid foam to the ceiling!
