Old 02-21-2018, 10:05 PM   #1
Steel Studs for Framing?
Has anyone tried using the steel studs for the interior wall framing?
Seems to be that they would curve better and would be lighter overall...
PNWorBUST72 is offline   Reply With Quote
Old 02-21-2018, 10:08 PM   #2
Chassis: Saf-T-Liner MVP ER
They would be both those things, and also a thermal bridge defeating your insulation.
They might work well for interior wall studs, but again you do not want any direct metal paths to the outer skin of the bus.
Steve Bracken
Build Thread
Old 02-21-2018, 10:14 PM   #3
BennysTire's Avatar
Chassis: TC-1000
Engine: 5.9 Cummins 24v
Rated Cap: 39 Students
My application for busses does not require temperature control for living quarters. My last 2 builds utilized wooden framing, but I have been contemplating going "all metal" on this one. So, I'll let you know how it turns out [emoji6]
Sent from my E6883 using Tapatalk
BennysTire is offline   Reply With Quote
Old 02-21-2018, 10:30 PM   #4
So if I used a strip of that radiant barrier stuff, would that be enough of a break?
Paint? Hardwood floor underlayment?
Old 02-21-2018, 10:36 PM   #5
BennysTire's Avatar
Chassis: TC-1000
It would be a break, sure... "Enough" of a break? 🤷
Old 02-21-2018, 10:47 PM   #6
Jdawgsfanasty's Avatar
Look up "blue collar preacher" on YT
Jdawgsfanasty is offline   Reply With Quote
Old 02-21-2018, 11:01 PM   #7
Also what if the ceiling was up first and I ran the interior wall studs against the finished ceiling? No direct outer skin contact that way...
Just thinking....who knows.
