Old 02-09-2015, 01:19 PM   #1
timbrass's Avatar
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
Stemco Wig Wag - What does it do? And Why?
It would appear to be related to compressed air and the STOP sign, but how does this STEMCO WIG WAG work and why do you even need it? Does it matter which way you push the lever? Why is in such a prominent position? I'm sort of guessing it is some sort of failsafe so the STOP sign works even when compressed air fails....
My Build site is https://schoolbusconversion.net
timbrass is offline   Reply With Quote
Old 02-09-2015, 02:58 PM   #2
http://www.stemco.com/product/wig-wags/
http://en.wikipedia.org/wiki/Wig_wag...raking_systems)
dond is offline   Reply With Quote
Old 02-09-2015, 04:19 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I think they're cool, first truck I drove with air brakes had one. It was a manual reset, won't stay up if air pressure is too low. There certainly isn't any doubt if the pressure goes down. I wish I had one just for the heck of it.
Old 02-09-2015, 05:13 PM   #4
Wig Wags came in several different versions, one of which is still required under state spe'c for NY.
If your air pressure for your brakes ever goes below a certain PSI it will drop. Which is why some of them have stop lettered on them.
Without air pressure you won't stop which is why it will drop before you can't stop.
Some, like the one pictured, have to be reset by hand. Others will go up as the air pressure goes back up.
Old 02-09-2015, 06:55 PM   #5
Chassis: AARE
Actually, without air pressure you WILL stop. Modern air brake systems use air to release the brakes. No air the brakes are on.
Old 02-11-2015, 09:05 PM   #6
Both are correct. The parking brake, or "spring brake," is set by a strong spring and held back during travel by air pressure. If you lose your air, the parking brake valve pops out releasing the "emergency" air. The springs are no longer held back and the parking brakes apply themselves.
On the handful of trucks I've driven, the front wheels have one air canister for service brakes only. The double canisters for service brakes plus spring brakes were only on the rear axle.
The foot pedal or treadle activates the service brakes by applying pressure to the system. If you lose air, the service brakes go away.
Dick is the professional driver, so I won't say there are not any systems with an air solenoid that inverts the air pressure and allows springs to set the service brake shoes, but I don't believe that is the way they commonly work.
Old 02-12-2015, 07:12 PM   #7
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
Originally Posted by Redbear View Post
Both are correct. The parking brake, or "spring brake," is set by a strong spring and held back during travel by air pressure. If you lose your air, the parking brake valve pops out releasing the "emergency" air. The springs are no longer held back and the parking brakes apply themselves. ...
I don't know when these systems first appeared, but interestingly, I discovered that Dodge trucks and school buses with air brakes are so equipped back in 1976.
After going thru. training and becoming a prof. school bus driver, I found out why so many folks here prefer air brakes. These emergency systems are a great idea!
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 03-11-2015, 06:02 AM   #8
timbrass's Avatar
Rated Cap: 29
A follow-up question...Having fixed the severed airline and run the engine, the Wig Wag stays "up". However the next day the air pressure has dropped (you can see from the air pressure gauge on the dashboard)
Is this normal? Do I need to try and find the leak or is this to be expected? I.e. when the bus is running the compressor produces lot of pressure so a little loss is not important. One side effect is that in order to run the radio and get rid of the low air pressure warning noise I have to run the engine - and running a big diesel for short periods is not a good idea.
Old 03-11-2015, 07:21 AM   #9
Chassis: AARE
I'll probably get jumped on here, but it is pretty normal. If the vehicle doesn't have an ACC position with the ignition key, I usually rewire the radio so it will play with out having the key on. You just have to remember to turn it off when you leave.
Old 03-11-2015, 12:02 PM   #10
Engine: TE 444
Rated Cap: 12
Air systems leak down over time, even when new, there are standards on how fast they can leak out but overnight is fine. The spring brake is piggybacked on the rear service brake, uses same brake shoes. Your low air pressure alarm should come on when the pressure goes below 90 psi, the air brake valve should pop out and set the spring brakes at about 60 psi. You can hold it in and drive until the pressure goes below 40 psi at which point the pressure is too low to overcome the springs
Old 03-11-2015, 01:01 PM   #11
I have seen air brake equipped buses keep their air pressure up for several days. They were the exception.
Most newer buses will keep their air pressure up overnight.
But a lot of older buses are hard pressed to keep their air pressure up for four hours.
A lot of the times the leaks that cause the draw down are so little it is hard to locate them. Sometimes all it takes is to tighten up a fitting.
What happens is the more air operated devices you have the more opportunities there are for air to leak. A bus with only air brakes and nothing else has a minimum of air lines and fittings. When you start to add air operated wipers, service door, rear suspension, front and rear suspension, front/drive/tag axle air suspension, driver's seat, horn, air locks on luggage doors, air throttle, air clutch, air transmission shifter, air operated damper doors in the HVAC system, etc. you end up with miles of air lines and forty-leven fittings. It becomes an impossible task to identify and repair every leak.
As long as you can build air pressure up in the required amount of time and it doesn't leak down in less than the required amount of time I wouldn't worry about it.
As it has been noted before, I would not operated the radio with the key in the run position. Outside of the fact you would have to listen to the buzzers going it can also cause issues with the brain boxes for the engine and transmission if the key is left on for extended periods of time with the engine off. It would be much easier to just get the hot lead to the radio connected to an always hot power point.
Old 03-12-2015, 12:05 AM   #12
Wig wag or buzzer or light come on at 60#'s air pressure not 90.
Aaron is offline   Reply With Quote
Old 03-12-2015, 05:37 AM   #13
my air pressure warning comes on at 60, not 90.
Old 03-12-2015, 01:55 PM   #14
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Bus might be different from a tractor?, but the tractor trailers I drove the light and buzzer came on at 90#.
Small air leaks are sometimes hard to find, spray bottle of soapy water on EVERY fitting.
Old 03-12-2015, 05:36 PM   #15
REDD's Avatar
Coachwork: Thomsass
I'm wrong.....it's been a while, 60#'s for low air buzzer and light.
Old 10-19-2023, 03:44 PM   #16
nikitis's Avatar
Rated Cap: 29
I know this is an old thread, but I want one of these Wig Wags. Where can I obtain one? How old of a truck to I have to find in a graveyard to find these installed on them?
New ones from Stemco are $568. Way too much in my opinion. I want to replace my buzzer with one of these. I can't find anyone selling them at a reasonable price. To me $100 to $120 would be reasonable.
I could go through the motions of making my own version of this with a arduino and an air pressure switch and a solenoid for less than $100, but it wouldn't be as cool looking as these originals.
nikitis is online now   Reply With Quote
Old 10-19-2023, 04:30 PM   #17
nikitis's Avatar
Rated Cap: 29
Update, I found one on auction for $165, pulled the trigger on it. New condition too in box.
Old 10-19-2023, 08:50 PM   #18
Wow nice, where can I found that auction is it online?
Jamessmith0901 is offline   Reply With Quote
Old 10-19-2023, 08:59 PM   #19
nikitis's Avatar
Rated Cap: 29
It was Ebay. The only other listing on ebay is $495.95 I don't think the guy who is selling it to me knows what he had.
Old 10-19-2023, 09:07 PM   #20
s2mikon's Avatar
Engine: Cummins 8.3
My 69 IHC bus has one. When dual circuit air brakes came out they disappeared. As to air leaks over 2 pounds per minute is out of service.
s2mikon is offline   Reply With Quote
