Old 06-01-2006, 11:47 AM   #1
Storage boxes under bus
Hi Everyone I'm looking for some good pics and how-to's on how to build storage underneath the bus.
So-far I found one idea from Damit Andy bus site.
But I'm looking for other ideas as well
http://www.miebad.com
littlee1441 is offline   Reply With Quote
Old 06-02-2006, 10:30 AM   #2
Storage Box Underneath
Does anyone have some good insight on how to build storage under the bus.
What tools work best, What materials work best wood, metal
What to use for latch and lock systems
Thank you http://www.miebad.com
Old 06-02-2006, 05:31 PM   #3
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
You can buy pre-fab boxes ("truck boxes") or make your own.
We did our propane tank storage like this. I tested it by scrunching my 190-lb self partially into the box -- no, I didn't fit but the box did take all of my weight without protest.
I think wood box construction with metal frame/support/bracing works. Others go with sheet metal box/metal frame.
You may be able to find truck boxes used or at a salvage yard.
Best of luck--
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
UNDER THE BUS BATTERY/GENY BOXES putterspitt Electrical, Charging and Solar 1 12-14-2010 07:55 AM
Welding Storage Boxes, Tank Frames elkoskoolie Conversion General Discussions 6 05-10-2010 09:05 PM
Storage Under the Bus littlee1441 Conversion General Discussions 3 05-23-2006 08:33 PM
Storage Help Please phillip266 Conversion General Discussions 4 08-22-2005 01:36 AM
Basement storage boxes busone Conversion General Discussions 6 06-03-2005 03:24 PM
