Old 07-11-2019, 11:52 AM   #1
Storage Clearance from Exhaust Pipe
Iím about to install tool boxes in the skirt just behind the rear wheels. The left side will be over the exhaust pipe. How much clearance do you think it should have?
File Type: jpg CB627AA5-C3B7-4CCD-B086-5DC238A79ECB.jpg (158.5 KB, 5 views)
File Type: jpg 73D3E543-7FEB-40AE-A3D0-16C22064DBB5.jpg (150.7 KB, 8 views)
Old 07-11-2019, 12:02 PM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
What're you gonna store in it, and are the boxes metal, or plastic?
Old 07-11-2019, 12:08 PM   #3
Good question.....
I have plans for a generator box above my exhaust. I am looking forward to the replies.
Old 07-11-2019, 12:19 PM   #4
HazMatt's Avatar
If protracted idling in a hot climate is anticipated, I'd be worried about excessive gas fumes being generated, presuming a gas-fired gen-set.
Good question.....
An exhaust re-route is another option to consider...
https://r.tapatalk.com/shareLink?url...2&share_type=t
Old 07-11-2019, 12:33 PM   #5
Hereís the box.
IDK what Iím storing just yet. Knowing myself, probably tools or fishing tackle.
File Type: png DCB423A5-546B-4412-AA0C-A817976F2D27.png (263.0 KB, 4 views)
Old 07-11-2019, 01:06 PM   #6
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
You might want to consider fiberglass cloth exhaust wrap. It's more for keeping heat in than preventing it from getting out (to maintain exhaust velocity for performance applications), but that's essentially two sides of the same coin. On an inline-4 you can hold your right on the collector 2' from the exhaust ports. So I figure in your application it would be more than sufficient.
Just an amazon search for reference. No endorsement of any of the specific products:
https://www.amazon.com/fiberglass-ex...s+exhaust+wrap
-Sharon & Jody
Mr Beefy Short Bus Acquisition & Build Thread
Old 07-11-2019, 01:47 PM   #7
Header wrap has been proven to have far more cons than benefits and the benifits are neglible in the most extreme applications. If it's not on a full out race car, it has little to no benefit. I doubt heat from the pipe will be an issue.
Old 07-11-2019, 01:56 PM   #8
I’m just going to do it. If I need clearance I can always drop the pipe an inch.
Old 07-11-2019, 02:22 PM   #9
Coachwork: IC
Rated Cap: 24
Well, in the context of this discussion, header wrap has one important proven benefit - containing heat that could otherwise prove detrimental to surrounding materials.
The heat that I'm familiar with doesn't really understand whether it's coming from a 'full-out race car', or a medium-duty diesel. But maybe the heat is smarter in Georgia.
-Sharon & Jody
Old 07-11-2019, 02:34 PM   #10
What's the temp surrounding the pipe? Or are you just guessing at fixes that may not be needed?
Old 07-11-2019, 02:49 PM   #11
Chassis: Blue Bird
Engine: ISC 8.3
Probably do equally well, or even better, to put the wrap or other high-temp insulation on the box rather than the exhaust tube.
Or stick a piece of sheet metal in between as a heat shield. We see those all the time on/near catalytic converters and mufflers - no insulation at all.
On second thought, take a closer look at that picture. It looks as if the exhaust "tip" (can we call it that?) is joined to the exhaust tube about 1.5 feet back from the exit, and there's some air gap in there. The exhaust flowing past that gap will create suction and draw ambient air in at that point. It'll mix and the gases exiting at the tip will be cooler. I'll bet the exhaust tip is cool enough that nothing more is needed. Run it hard and then splash some water on the metal. Does it sizzle? Wet a finger and quickly touch the metal. Did you feel any heat?
Old 07-11-2019, 03:16 PM   #12
Coachwork: IC
Rated Cap: 24
No, Marc. I'm providing a potential solution IF the temperatures surrounding the pipe and the items he's planning to place in proximity require it. It's up to the OP to decide if they do. The very fact he posted the question suggests that he's concerned about heat. So a heat-mitigating solution seemed to be of value.
Contrast that to your assertion of "I doubt heat from the pipe will be an issue", without any idea of what the temps are, how close he was mounting the items in question, or what the items were composed of. And assertion which, ironically if not surprisingly, is exactly what you're accusing me of providing... an uneducated guess.
-Sharon & Jody
Old 07-11-2019, 03:17 PM   #13
Coachwork: IC
Rated Cap: 24
Best answer yet.
-Sharon & Jody
Old 07-11-2019, 06:12 PM   #14
Ronnie's Avatar
Engine: 345 international V-8
My exhaust runs about 1.5" under the black tank and the tank is plastic. 11,000 miles so far and no problems.
Old 07-11-2019, 07:04 PM   #15
My factory exhaust runs parallel to the back of the storage box about 6" behind it. How close do you want to mount your box ?
exhaust
