Old 02-02-2008, 06:58 AM   #1
stove mounting
I just got a stove-oven combo for my bus project. Do you guys have any guide lines as to mounting? It is a magic chef brand with four burners and oven. I need to know if it needs to be vented to the out side, plus the side clearance numbers. Will it need a regulator, don't see nothing but a flare fitting on the header with the controls. thanks.
odee is offline   Reply With Quote
Old 02-03-2008, 09:35 AM   #2
Re: stove mounting
the one in our camper isn't vented,outside of a hood fan...propane gives off a lot of water vapor and that needs to go outside.
Demonknight is offline   Reply With Quote
Old 02-03-2008, 05:03 PM   #3
the_experience03's Avatar
Re: stove mounting
Mine also lacks venting. I don't even have a hood. I just open the window (yep, it sucks). As for clearances...mine was a zero clearance model meaning that metal case that can be seen around it can be mounted directly to whatever. I would imagine there is an internal chamber between that outside casing and the actual oven which serves as the clearance. I just use a regular gas grill regulator.
Old 02-03-2008, 08:11 PM   #4
swinada's Avatar
Re: stove mounting
put your model # in to this site and see if it gets you anything.
http://shared.whirlpoolcorp.com/prod...jsp?siteCd=MCF
I for sure recommend getting a hood for it.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Mounting generator opus Electrical, Charging and Solar 5 09-11-2010 10:39 AM
Generator mounting Diesel Dan Conversion General Discussions 2 01-27-2010 06:47 PM
Holding Tank Mounting wdbowers Skoolie Conversion Projects 17 09-17-2008 02:23 PM
Generator mounting eggman Conversion General Discussions 18 02-28-2007 09:39 AM
Mounting generator under bus has anyone done this and how. heath692 Conversion General Discussions 3 04-25-2005 10:34 PM
