Originally Posted by o1marc
My bus was stuck in limp mode in 2nd gear. I'm told it could have been something as minor as a blown fuse. I'm looking at another bus that is stuck in reverse. Any ideas on what may cause that? 1990 BlueBird, probably a 545?
mechanical trans.. its likely the shift cable is broken or is stretched.. depending on the shifter it has.. some of the shifters were gated and if the shifter itself jammed.. (the release button got stuck) then you couldnt physically move it out of reverse..
nevertheless in 1990 everything weas mechanical. and unless only reverse works (and forward gears are no-motion) then id bet its a shift-cable issue.. if a bus sat for a long time that shift cable can get moisture in it and rust to where it wont move in the jacket.
