Old 10-14-2017, 01:52 PM   #1
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Subfloor and insulation... Furring strips vs No furring strips
Hey guys...
Going into town here in a few hours and has a quick question. I've seen subfloors in some of these builds done with furring strips... some done without. What are the pros/cons of each?
I was planning on not using furring strips. My bus has 3/4 plywood floor already (no metal under). I was planning on going over this with 3/4" or 1" XPS and 5/8 plywood. The plywood will be screwed down with countersunk screws to not interfere with the floor covering.
Will this be ok?
Old 10-14-2017, 01:58 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by Mr4btTahoe View Post
Hey guys...
Will this be ok?
If you use the high-density foam and put plywood over, you'll be good without furring strips to spread the load. If you go Styrofoam, they suggest the strips. 5/8 ply is fine. 2" XPS would be more better if headroom allows.
Old 10-14-2017, 02:42 PM   #3
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Headroom would be getting snug loosing another inch of space. I'll take some measurements and see where we are at. Wont bother me but the wife is taller then I am (I'm 5'9.. she's 5'11). Don't want her to be feeling like she needs to duck all the time. Lol
If we've got the room, I'll go for it.
Thanks
Old 10-14-2017, 02:51 PM   #4
Traveling
Rated Cap: '00
Thanks
I have a 5'11 redhead, 'nuff said.
Old 10-14-2017, 02:54 PM   #5
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Gotta love em'!
Old 10-14-2017, 07:22 PM   #6
T-Bolt's Avatar
Engine: DT530
Owens Corning Foamular 250 has a rating of 25 lb per square inch. The plywood over the top of that you should have no need for furring strips.
Sent from my SAMSUNG-SM-G930A using Tapatalk
T-Bolt is offline   Reply With Quote
Old 12-10-2017, 04:24 PM   #7
golfersmurf57's Avatar
Ok finally something I need I weigh about 265 on a size 12 workboot. This gonna support my fat azz? Also what kind off R factor we talking and if ya double it up will it chafe and loosen or (yikes!) squeak?
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
