Old 09-24-2014, 05:00 PM   #1
r_w
Sunken tub/Lowering the floor??
OK, I can't go up unless I also raise the roof of my barn and the railroad underpass just down the road, so....
Has anyone put in a sunken shower base? I figure I can drop it 8" or so and still have room to run plumbing and INSULATE it. Probably find a large one-hole kitchen sink and go from there. Other than proper support and access for repairs, any other things you could see as a problem?
r_w is offline   Reply With Quote
Old 09-24-2014, 05:09 PM   #2
Re: Sunken tub/Lowering the floor??
I am planning the same thing or put in a bubbled skylight
I figured I would cut my hole, make a steel frame out say 3/16 x 3 and weld all the body channels to it, add a few triangles and then use it for my dropped "wall" and build down from there and then across finish the sunken floor
I do not see an issue, be aware of frame location and make sure you have access from top/bottom and sides to weld
Old 09-24-2014, 05:31 PM   #3
I sunk my bath/shower 7" with no problem other than I had to put a lift pump in because the shower drain is lower than the grey water tank. Jack
Old 09-24-2014, 05:56 PM   #4
r_w
Good to know. No problem using a sump pump, in fact that makes a lot of things easier.
I thought about a skylight, but I just can't see cutting a hole in a perfectly good roof if I don't have to.
Old 09-24-2014, 08:23 PM   #5
I'm tall so even with the sunken bath I still had to build a pop out on top so I could stand up. Mine is a welded structure that makes it a permanent part of the roof--so no leaks. Jack
Old 09-24-2014, 08:31 PM   #6
r_w
That is an option, although my welding is seldom leak proof. Although I should get close enough elastomeric would solve the rest.
Old 09-25-2014, 11:01 AM   #7
mtunderwood's Avatar
Engine: 5.9L Cummins
I was just thinking about this the other day. I went to a big RV show in Orlando and noticed a few smaller rigs that had either a sunken shower pan or a raised bubble for your head. The "head bubble" seemed weird... like showering in a space station. If I had to pick between raising a roof though, or lowering a shower pan and adding a pump... I'd go with a pump.
I imagine you could cut out the opening, weld in a steel "cage" to support the pan, then just frame it in with wood and drop in the pan. If that doesn't work, cover the hole with 1/2 plexiglass and you have a floor-light! GENIUS!
-Mikey
Website - https://suziebluebus.com
Build Thread - https://www.skoolie.net/forum/viewtopic.php?f=9&t=468143
mtunderwood is offline   Reply With Quote
Old 09-25-2014, 11:14 AM   #8
ole Skool glass bottom boat...urgh...skoolie
sunken tub/shower bansil Plumbing, Water and Waste 30 02-26-2020 09:29 PM
6'3" - ? Lowering floor allanwcoty Conversion General Discussions 5 11-06-2018 02:07 PM
almost there with the floor butcher_boy Conversion General Discussions 2 06-07-2011 12:33 PM
Floor question retrogeek42 Conversion General Discussions 7 10-31-2008 11:38 AM
3/4 ply vs 3/4 osb for floor busone Skoolie Conversion Projects 6 10-09-2005 09:07 PM
