Old 09-25-2013, 04:26 PM   #21
Re: sunken tub/shower
oh yeah it will be braced, also doing it in the rear corner on drivers side so the factory braces will still be there, and it will be braced to the frame underneath like a fuel tank to a frame (big rectangle tanks on the side of truck frames)
since this area is past the suspension points and such floor flex/twist shouldn't be an issue (also that area of the frame also has a "roll cage" for support and protection of the fuel tank)
also plan is to not really support it with the bus floor
I still have to get underneath and measure etc...in my head it'll work...
also a sunroof bubble is still a possibility also...so maybe won't go thru the floor.
we'll just have to see
Old 09-25-2013, 08:46 PM   #22
roach711's Avatar
Rated Cap: 19
Originally Posted by JakeC
That's what I had in mind. Go to the Tractor Supply Store and get a good sized galvanized tub, cut in a drain and mount a surround shower curtain around it. Now you have both without having to recess anything.
The Roach Motel
Old 09-25-2013, 10:00 PM   #23
Engine: 190hp 5.9 Cummins
Is your fuel tank suspended by the roll cage, or mounted on it's own, and just protected by the cage?
If the tank mount is separate, do your self a favor and drop that 750 pound boat anchor. My B700 felt relieved the day I got rid the one it had hanging there on the passenger side. Talk about loaded to one side. 90 gal of fuel, a 200 pound tank, and 750 pounds of unneeded steel.
Old 09-26-2013, 05:34 AM   #24
the cage supports the tank between the frame rails...I never want to be near it if it gets hit hard enough from the side or rear to rupture the tank, that's for sure
Old 09-26-2013, 05:35 AM   #25
I am too tall with out a roof bubble or sunken floor
Old 09-29-2013, 04:45 PM   #26
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
That's funny... I have that same water trough to water my cows.
Don't means to steal the thread but I do have a question....
I am going to try and do a shower toilet combo sort of like this.....
I have a regular RV toilet so not sure if it will cause any issues. To me this is one of the best ways to have dual purpose of space and use it wisely. Would like to know if there would be any known issues of doing it this way?
Old 09-29-2013, 09:08 PM   #27
Bapos, not to continue the thread theft I'll just say that that is how many of the smaller R/Vs and trailers of the '70s were put together. As long as you aren't too tall or too big around it works fine. My bus is only 5'5" tall inside so I built a pop-up and dropped the br 7 1/2" so I can stand up. I am using a sump pump to transfer shower water to the grey tank as the drain is too low to work otherwise. Oh, the regular toilet will work just fine. Jack
Just cut a hole in the floor and sink the entire bathroom. I chose 7 1/2 " drop because it is a common stair rise.
Old 09-29-2013, 09:59 PM   #28
bapos's Avatar
Well me being tall and big kind of jacks that up.... Im 6'3" and 260 lb so yeah I see issues. Ill find a way to make it happen. More worried about the toilet things than the shower as that is not a huge need but more of a convince. We all need to drop cargo?
Old 02-26-2020, 08:34 PM   #29
The Wandering Dragon's Avatar
Year: 1972
Engine: 555 Cummins
I Doing This In My Bus.... Im Sinking The Wine Barrel Into The Floor About 4 inches, I still have to make a tray, and the water will drain into grey tanks mounted directly under the tub... This Is more of a Soaker Tub, as I Fit, but would not to be in it daily, and is still big enough to have a shower in...
The Wandering Dragon is offline   Reply With Quote
Old 02-26-2020, 08:35 PM   #30
Year: 1972
Engine: 555 Cummins
[IMG]file:///C:/Users/Robert/Pictures/The%20Wandering%20Dragon%20%20Bus/20180616_211303.jpg[/IMG]
Old 02-26-2020, 09:29 PM   #31
Welcome to the sunken floor club. I don't think anybody here has access to your C: drive, unfortunately.
Shower Stalls, Shower Stall Pans Ryan Grimm Conversion General Discussions 7 06-30-2020 02:58 AM
Sunken tub/Lowering the floor?? r_w Conversion General Discussions 7 09-25-2014 11:14 AM
How big is your shower? syke Conversion General Discussions 10 04-06-2012 05:02 PM
Shower pan Diesel Dan Plumbing, Water and Waste 17 01-26-2011 10:37 PM
shower pan GoneCamping Conversion General Discussions 1 06-24-2007 06:45 AM
