Old 04-16-2017, 09:19 PM   #1
Question surface preparation for spray foam
Hi.
After removing the interior panels I realize that the insulation was glued with some kind of tar material and it is quite hard to remove it , looks like undercarriage paint and I was wondering if is needed to get that cleaned up before getting it sprayed ?
I will take my bus to a local company to do it but I want to star preparing for it.
Thanks.
pepepito is offline   Reply With Quote
Old 04-18-2017, 09:10 AM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by pepepito View Post
Hi.
Thanks.
My understanding people remove the tar because of leaks & rust, I spent many hours in my bus with a flashlight during many rain storms & didn't notice a single leak so I left mine in, Some will disagree with me
Old 04-18-2017, 10:48 AM   #3
Robin97396's Avatar
I agree with Stu & Filo. T. The tar appears to be intended to hold the wool insulation in place, or some others say it was applied as a rust preventative. I don't believe the coverage is complete enough to work as a rust prohibitive coating. The unsprayed areas of the ceiling had no signs of rust at all. I saw no signs of rust or leaks indicating the tar needed to be removed. I considered attempting to remove the tar because some other people here were removing it from their ceilings.
It's way to cold to scrape off tar from the ceiling in Oregon. It would likely chip off unless the removal was done during the heat of the summer. Otherwise chips of tar would land everywhere and make a big tarry mess on the floor. Personally I take a shortcut when I can, so I had the foam guy just spray over the tar. I don't have any experience to compare this foam job to so it's difficult to say what is the best way to do things in preparation for foam.
I liked the idea of completely filling the cavities between the ribs with foam, rather than applying a 1/2" layer of foam. That issue is what caused me to shy away from the kits and lean toward the commercial spray foam. I'm sure there are advantage and disadvantages to either method. I've only done one method so I can't say which is best. I sure did feel warm in my bus this recent winter, and I put much less energy into staying warm. Worth it.
Robin
Nobody's Business
