I drive with a full tank of water and it helps the ride, also I weighed my bus, and lowered my tire pressure, you go on line to the tire manufacture for psi, also I replaced my drive tires with new summer ones instead of the snow tires that where on it, big difference in noise, and a bit smoother ride, this spring ill replace the shocks for some better ones this will help for some of the pounding from road joints. each one of these changes added up to a better ride, not fantastic , but a lot better.
