Old 03-13-2015, 08:31 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Switch source
I'm hunting in vain for a SPTT switch. Has anybody any ideas where to get one? Its the toggle switch that controls my wipers - off, lo, hi or off on on. Mine is broken - its a bitch to get the damn wipers to turn off once they're on!
Zephod_beeblebrox2 is offline   Reply With Quote
Old 03-15-2015, 02:56 AM   #2
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
Switch.
Go to ebay and search for 3 position 12v toggle switch.
Hopeless Busaholic!
Roadrunner is offline   Reply With Quote
Old 03-15-2015, 07:28 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Center off DPDT switches are quite common.
Here's just the first search I did.
Amazon.com: Heavy Duty Toggle Switch DPDT Center Off 20 Amp: Automotive
Off On On not so much, I don't see any reason On Off On would work for you application.
Old 03-15-2015, 08:57 AM   #4
If you want the aircraft look you can also try here:
B&C Specialty Products - Switches
Used them a lot for the plane. They have every combination you can imagine. It looks like a short list but it's because the first page is just the number of poles. If you click single or double pole then you can choose any combination of off/on/momentary you want.
I've also had really good luck with these guys, who carry a lot of the weird stuff you sometimes want in automotive work, like weather-tight power connectors, etc:
Toggle Switches | Automotive & Marine Toggle Switches | Waytek, Inc - Page 1 of 6
And if you're on a budget, keep your eye on these guys:
Switches - Toggle | All Electronics Corp.
All Electronics, AllTronics, and a few other electronics shops have all sorts of funky things. If you like lighted or oddly-shaped switches, they're a good place to look.
taskswap is offline   Reply With Quote
