Originally Posted by talk2cfs
Wanting to switch from 2b carb to 4b carb. Does anyone know what intake i need for the Ford 370? Also any clues on how to remove the speed govenor from my current 1989 B700 with a 370? Anyone pulling a boat with there bus? If so what kind a gas milage you getting? Thanks
Why are you wanting to go to a 4b carb?
Usually a 2b works better for torque than a 4b carb, I would worry about mpg really going bad by installing the 4b. The factory's did a lot of testing to setup a engine with the proper carb for the application...
