Old 04-29-2008, 10:09 AM   #1
Chassis: Ford B700
Engine: Ford 370
Switching from 2b Carb to 4b Carb?
Wanting to switch from 2b carb to 4b carb. Does anyone know what intake i need for the Ford 370? Also any clues on how to remove the speed govenor from my current 1989 B700 with a 370? Anyone pulling a boat with there bus? If so what kind a gas milage you getting? Thanks
talk2cfs is offline   Reply With Quote
Old 04-29-2008, 02:27 PM   #2
Re: Switching from 2b Carb to 4b Carb?
Why are you wanting to go to a 4b carb?
Usually a 2b works better for torque than a 4b carb, I would worry about mpg really going bad by installing the 4b. The factory's did a lot of testing to setup a engine with the proper carb for the application...
hoser is offline   Reply With Quote
Old 04-29-2008, 10:16 PM   #3
the_experience03's Avatar
I agree, keep the 2BBL. The funny thing is that 2 barrels and 4 barrels have their volumetric flowrate calculated differently in that one is at 3 inches of mercury while the other is at 1.5. This means that a 500 CFM 2 barrel flows more air than a 500 CFM 4 barrel if that makes sense.
That aside...if you want a 4 barrel carb I don't see any reason why an intake off any other 385 series Ford won't work. I don't think the 370 was a "tall deck" so any 4 barrel 370, 429, 460, or 514 intake should work just fine.
Old 05-14-2008, 12:14 PM   #4
Chassis: Ford B700
Engine: Ford 370
Thanks. I think I will just keep to the 2b. Any ideas on how th remove the gov. on this carb?
366 carb to 427 FI swap!! jaredg GM | Chevrolet Drivetrain 13 02-18-2015 09:01 PM
California CARB laws eddieifft Short-Bus Conversion Projects 1 12-13-2014 05:28 PM
Need carb for Dodge 360... 2 barrel frank-id Classifieds | Buy, Sell, Swap 2 08-21-2014 09:14 PM
366 BB Carb Choice Gyva GM | Chevrolet Drivetrain 7 09-19-2010 08:57 AM
Carb Idenification dragonfly112 Conversion General Discussions 2 09-05-2009 09:05 PM
