Old 11-23-2011, 05:26 PM   #1
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Switchplates and switches
Lots of big stuff on the board, thought I'd put in some small stuff.
Just some ideas for making switches and using plain old switch plates for other things.
I guess these are pretty self explanatory, the light switch in the wall on the left is a lighted LED switch, about a buck a pice in lots of ten on eBay, they snap onto a 3/4" hole. To the right of the AC outlet on the monitor panel is an RCA connector mounted on a single blank plate used as a 12 volt outlet.
Close up of above - the top switch to the left of the meters turns the inverter on and the lower two switch the battery banks.
Close up of switch -
From the left - entrance light switch, pump switch and the three vertical LEDs are the fresh water level -
Soffit light fixture made from one of those puck light that come in sets of 5 from Home Depot, a lighted LED switch and a double blank switch plate.
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 11-23-2011, 06:15 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Switchplates and switches
Nice looking work.
Old 11-24-2011, 11:21 AM   #3
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Very nicely done
Old 11-25-2011, 09:31 AM   #4
Stuff's Avatar
neat switches!
Old 11-25-2011, 06:42 PM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
Thanks for the idea! I'll be on the lookout for a good application for switch covers in my bus! Sometimes the little things are even more satisfying than the big things. More bang for the buck!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-29-2011, 03:02 PM   #6
browncrown's Avatar
Rated Cap: 79 at Birth
I really like those cool switches!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 11-29-2011, 03:23 PM   #7
wtd
wtd's Avatar
Year: 1982
Thanks all.
The LEDs in the water gauge work off 12 volts, they come with the resistor wired in, have 12" leads and as I recall they were about a dime a piece on ebay - bought a bag of them and use them all around the place. They make nice 'nite-light' things, too - just wire 'em up and leave them on all the time, they only draw 10 mA or so, placed right they'll give you enough light to get to the icebox or the can at night without tripping over anything, but not bright enough to bother you. They fit in a 5mm hole.
Tom
Where DIY meets WTF
Anybody have excess Carling 12v Switches? jazty Conversion General Discussions 6 12-11-2014 05:11 PM
Existing lights new switches 12v advice. ThePimentals Electrical, Charging and Solar 12 08-12-2014 10:52 AM
Electrical Safety Switches DaRealGuru Electrical, Charging and Solar 6 10-08-2013 02:20 PM
Want/need Blue Bird switches frank-id Classifieds | Buy, Sell, Swap 2 03-25-2008 01:40 PM
House-like 12 volt light switches TomCat Conversion General Discussions 7 08-03-2005 01:07 PM
