Old 01-11-2013, 12:37 AM   #1
Tag axle on pusher?
When I finally get a bus to convert, I want it to be a flat nose pusher. I intend to put a trailer hitch on to tow with. To add stability and increased tongue weight capacity, would a tag axle be practical or even possible? If yes to both, would it be better behind or in front of the drive axle?
stonestatue is offline   Reply With Quote
Old 01-11-2013, 02:04 AM   #2
crazycal's Avatar
Re: Tag axle on pusher?
Motor coaches have a tag axle. I don't think it's worth the effort or the cost. Only my two cents.
I'm hungry!
You Gotta Let Me Fly
Old 01-11-2013, 07:43 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
I really don't think it necessary, unlike a motor coach, a school bus is basically a truck. Not sure what you are towing, but,
it would take a LOT of tongue weight to be too much. A properly set up and loaded trailer won't have all that much tongue weight.
Old 01-11-2013, 10:30 PM   #4
Because from what I've seen, RVs are only rated at 5,000 towing capacity, although I'm sure there are a few greater than that. I've read others mentioning tongue weight being an issue, especially if there is a long overhang behind the rear wheels. I would mostly likely tow a boat, but I like to know what I'm getting into.
Old 01-12-2013, 08:27 AM   #5
GreyEagle's Avatar
Everything you always wanted to know about tag axles...... http://blog.rv.net/2008/11/how-to-justi ... ext-coach/
look under Legacy Suspension Systems http://www.morryde.com/downloads.html
mor ride........ http://www.morryde.com/
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 01-13-2013, 09:33 AM   #6
Rated Cap: 47
Motorhomes often have a very light frame at the back, and are toward or over their GVW rolling out of the factory. These are more limiting factors to their low tongue and low GVCW ratings.
A school bus has a truck frame from front to back, and is built to carry a substantial amount of weight. For instance, the f600 chassis my bus is based on would carry 15,000 lbs plus of grain as a farm truck.
Motobus is offline   Reply With Quote
axle ratio change kotflb Everything Else | General Skoolie Discussions 16 11-01-2017 08:28 PM
Tag axle question Stuff Short-Bus Conversion Projects 1 08-29-2011 01:32 PM
Bus Axle Lube Level? hoser Mechanical and Drivetrains 3 08-05-2010 08:43 PM
Rear axle or 2 speed axle hoser Everything Else | General Skoolie Discussions 7 09-10-2006 09:56 AM
AXLE IDENTIFICATION lapeer20m Everything Else | General Skoolie Discussions 7 06-22-2006 10:16 PM
