Old 01-30-2017, 11:46 AM   #1
Take top off and build rv
I was wondering if anyone has ever taken the whole rear (where the seats are) off and used the "flatbed" to build a tiny house from.
I've been searching a lot and being 6' I need it to be taller. The roof raise is a very good idea but seems like out of my skill area. Trying to do this and save money.
I've seen a few schoolies where people have basically made a tiny house camper out of the whole rear by removing the roof and walls. I'm wondering if any of you have done this and how it went for you the legalities etc.
THC4 is offline   Reply With Quote
Old 01-30-2017, 12:13 PM   #2
Chassis: MVP
Engine: CAT 3116
I'm a little confused, a roof raise is beyond your skill level, so you want to take everything off and build a home from scratch on the flatbed?
A lot easier to raise the roof!
Piersg is offline   Reply With Quote
Old 01-30-2017, 12:21 PM   #3
I have a lot of experience in carpentry, plumbing and electrical. However, welding isn't one of my strong points. Then making a front and rear cap. My original plan was to buy a camper use the trailer to build fro s scratch. But after seeing all these schoolies, I'd like to do the camper to tiny house idea but with a bus.
I'd have to buy a welder, learn to use it etc. I'd like to just hacksaw the whole rear and build from the floor up.
Old 01-30-2017, 12:25 PM   #4
I wouldn't be so quick to discount the roof raise based on skill level. If you have the skills and determination needed to chop a bus down to a flatbed and build a house on it, then I propose you have the skills (or could easily acquire them) to raise a bus roof.
If you've looked at a few builds, then you've probably notice that there is no standard way to approach the roof issue. I've seen people lift it with floor jacks and 4x4 poles, some winch it up with chains, and at least a few people have made custom fabricated metal brackets that used threaded rod to allow fine adjustments. Some of the frames are welded back together. Some people just acquire metal tubing of the appropriate size and bolt everything. Some of the outer skins are welded, some riveted, and I think at least one person mostly used self tapping sheet metal screws.
There's a lot of variety in approaches based on individual skills and resources. If you like the roof raise concept, then don't discount it too quickly. Especially if your goal is to conserve funds, then you have to remember that using the resources you have (ie an already mostly weatherproof shell) is typically going to be cheaper than making changes which will require you to totally rebuild something.
On the other hand, if something just appeals to you about stripping down to the deck and working your way back up, then that's up to you. Still, I'd caution that you are unlikely to be able to recreate something which will have the structural integrity of the bus shell you lose in the process. One of the biggest appeals of skoolie builds is often the safety that comes from having a solid metal shell around your mobile dwelling vs a bunch of laminated pasteboard like many RVs are built out of.
lucasd is offline   Reply With Quote
Old 01-30-2017, 12:45 PM   #5
turf's Avatar
spend $500 on a welder friend to do the needed welding. hacksaw and raise the roof yourself. you cant learn to do great welds in the little welding a roof raise takes.
but, scrapping a sturdy steel frame for a stick and staple one, well that just aint right. if you are a skilled carpenter, what you screw your work to shouldn't matter.
isnt there a thomas with a 7' roof? i'd keep shopping for something that fits your needs.
oh, and saving money and owning a bus don't really go together.
Turfmobile Build Thread
Old 01-30-2017, 02:06 PM   #6
Maybe I will keep looking for a 7 ft. That will work great. I am just leaning more towards this bus project vs a camper trailer because my truck will probably not pull a 27 foot camper too well. 03 ram 4.7.
I am 23 years old and planning for this to be my full time home, ready to get out of my parents house, but lucky that I can stay here while I save more money. I have about 3000$ right now and a stable plumbing job.
I will look into getting a welder and look at more people doing this.
Old 01-30-2017, 02:35 PM   #7
IF you cant weld or get someone to do it for you, you could always bolt or rivet. More than one way to skin a cat.
Great screen name, btw.
Raising the roof is gona save you a ton of hassle and will keep the integrity of the bus body more intact.
Roll Your Own Build Thread
Old 01-30-2017, 02:40 PM   #8
That sounds like a good approach if you want to make something for yourself that will really last.
Now, if you need something quick, you can get used RVs that are in remarkably decent shape for just a few thousand. The caveat there is that I can tell you from experience they are made for intermittent use. Full time living introduces wear and tear they were not designed for and quickly causes issues unless you start replacing the lowest-bidder integrated equipment with better stuff. And the insulation/climate control usually sucks.
Old 01-30-2017, 03:30 PM   #9
Phatman's Avatar
everything they said !!!!!!!!
Old 01-30-2017, 03:42 PM   #10
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
You can also expand your search for high roof buses, IC Buses (Amtran, International) came with 78" roofs standard around the early 2000s. Mine's 02/03, and has the 78" roof. Easiest way to tell the bus has 12" tall windows is to see if the driver's window height lines up with the others. If they don't, its a 78" bus.
Captain Obvious on deviantArt
