Old 11-27-2007, 04:05 PM   #1
KC10Chief's Avatar
Rated Cap: 60
Tankless water heaters
I can't remember if this has been covered already, but I'm seriously looking at using a tankless, propane water heater in my bus. They take up a lot less room, use less gas, and you have an endless supply of hot water as opposed to just a few minutes like you would with a regular RV water heater. Does anybody have one in their bus? I'm looking at one of these babies on E-bay:
http://cgi.ebay.com/LPG-Gas-10-Liter-Ta ... dZViewItem
I figure for the price, it's worth a shot. It's cheaper than an RV water heater as well. Also, does anybody use copper tubing for any of their water lines? I think Jake Von Slatt did for his shower. Any reason you should use copper and not just use PVC? Seems like PVC would be better. It doesn't corrode, sweat, and it's a lot cheaper. Thanks for your thoughts!
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 11-27-2007, 05:27 PM   #2
KC10Chief's Avatar
Rated Cap: 60
Re: Tankless water heaters
HA HA! Seriously? Had you seen them before I posted the link? I'm still a couple months away from needing one, but I'll let you be the guinea pig and test it out! Let us know how it goes!
Matt
7.3L diesel w/AT545
Old 11-27-2007, 06:19 PM   #3
crazycal's Avatar
I think that bus "Aimless Pursuit" had one. Here's a pic.
I'm hungry!
You Gotta Let Me Fly
Old 11-27-2007, 08:23 PM   #4
KC10Chief's Avatar
Rated Cap: 60
Holy crap! That thing is huge. Anyways, I was going to make a thick wall between my bathroom and kitchen and put the water heater in there. I knew they had to be vented, but I wouldn't buy the installation kit. I figure you can find most of that stuff locally. If anything, you could use some automotive exhaust pipe. I'm not sure if there needs to be a clearance or not. From everything I've read, you should be able to use PVC for everything. These things heat the water to about 120 degrees. That's nowhere near hot enough to hurt PVC. I've also wondered about the RV shower heads they sell on E-bay that have heaters built into them. They sell for about $50.
Matt
7.3L diesel w/AT545
Old 11-27-2007, 08:27 PM   #5
KC10Chief's Avatar
Rated Cap: 60
It looks like the installation kit is nothing more than some braided water lines and a couple fittings. You can probably find that stuff at a hardware store for cheaper than that.
Matt
7.3L diesel w/AT545
Old 11-28-2007, 07:50 AM   #6
swinada's Avatar
We talked about these heaters here
http://www.skoolie.net/forum/viewtopic.php?f=11&t=2324
and here http://www.skoolie.net/forum/viewtopic.php?f=11&t=2071
COMA bought one and was going to report back to us with his experience, but so far we didnt hear from COMA yet. Maybe he is so frustrated with them that he gave up. I was holding off on buying because i read some not so good reviews about the Mary heaters.
The one in the picture above is a BOSCH and costs way way more money.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 11-28-2007, 08:27 AM   #7
crazycal's Avatar
Maybe you can adapt something like this. I think it would be cheaper.
I'm hungry!
Old 11-28-2007, 09:04 AM   #8
lapeer20m's Avatar
i just brought home my idea of a tankless hot water heater.....
(this isn't mine, just some photo i found online)
It's a 115K btu fuel oil boiler.
Old 02-24-2008, 08:03 AM   #9
the_experience03's Avatar
Well...it's not as bad as the typical spammer's post.
Old 02-24-2008, 09:30 AM   #10
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Actually, his prices aren't bad. The only problem is; most of us are looking for propane types.
I actually tried the small shower type, a long time ago (about 40 years ago), and it worked pretty good. The only problem was, at that time, the reliability. The heater would only last about a year and the coils would give up.
I'm sure that, by now, the reliability has improved.
$45 for a small shower one, might be worth a try.
BTW, did you check out the passive water heaters?
Roasting8 is offline   Reply With Quote
RV On Demand Tankless Water Heater lornaschinske Conversion General Discussions 3 01-26-2011 08:47 AM
Tankless LP hot water heaters on the CHEAP! tfdfyrman Conversion General Discussions 3 07-03-2009 10:16 PM
Tankless Water Heater (link, under $200) fireman69 Conversion General Discussions 2 10-30-2008 11:54 PM
MAREY Tankless Water Heater Coma Conversion General Discussions 18 07-09-2008 08:18 PM
flea bay tankless water heaters. delbertinie Conversion General Discussions 43 02-26-2008 12:32 AM
