Old 07-07-2019, 09:33 PM   #1
Coachwork: Ford
Chassis: E450 Super Duty
Engine: 7.3L Turbo Diesel
Rated Cap: Over 1 million bad ideas
Temporary bolt hole fillers?
The bus I bought to convert was previously a work vehicle and the owner has mounted several large eye-bolts (maybe 3/8" bolts?) on the inside and outside of the bus. Because they run all they way through, they're holding down some panels I'd like to replace or at least remove for remodeling. I'm thinking I may actually want to use the holes in the future (since they're there anyway) so I'm wondering about ways to temporarily patch the hole while I work on the inside - maybe 12-18 months (at my slow-arse pace). At that point, I can repurpose the holes I want and permanently seal up the others. The bus wouldn't be actually used during that time, though I'm sure it'd go through a rainy season.
One option I was thinking of was to just wad up some butyl tape and stuff it into the holes.
Or possibly get a rubber plug like https://www.amazon.com/Rubber-Winter...dp/B0176XHVFA/ or https://www.amazon.com/CAPLUGS-Assor.../dp/B077R2MLV2
Anyone have any input on either of those (or other ideas?)
Thanks!
cweiss is offline   Reply With Quote
Old 07-07-2019, 10:05 PM   #2
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
You don't mention and pics aren't clear where exactly these holes are. You offer some interesting ideas, but I think you're overthinking this. When seats were removed from my previous B700, I filled them with clear silicone, obtainable at any auto parts store. Those bolts weren't much bigger than 3/8, if they even were bigger. Smeared an inch or two out from, and built up properly in/over exterior roof holes, clear silicone should keep the elements out as long as the exterior surface surround any outside hole is cleaned prior to filling.
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
Old 07-07-2019, 10:24 PM   #3
Rivetboy's Avatar
JB weld a penny on them . Remove them with a cold chisel and a hammer.
Rivetboy is offline   Reply With Quote
Old 07-07-2019, 10:28 PM   #4
Coachwork: Ford
Sorry, the bolts are going through the roof. There's similar ones around the windows on the side where the previous owner had bolted bars for security, but they're in poor re-use locations so I'll fill them permanently right off the bat.
I've got silicone, JB, and pennies - Sounds like I'm set
Thanks!
Old 07-08-2019, 02:10 PM   #5
bubb, the real one's Avatar
Coachwork: Thomas/International
Chassis: 3700
Engine: 7.3
Put caulk around the hole, then put a short bolt into the hole and tighten, it tightening it makes the roof bend or deform use glue instead of caulk so you dont have to tighten it too much.
Or... get some roof seal tape, one name is butyl tape, just tape it with this stuff and forget it, it will seal it for many years.
my bus thread, http://www.skoolie.net/forums/showthread.php?t=8860&highlight=bubb
bubb, the real one is offline   Reply With Quote
