Old 03-10-2006, 06:32 PM   #1
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Texture on the ceiling
Has anyone texture the ceiling????? I was thing about doing it but. 1. I don't know if it would stick...And 2. If I could paint it with automotive paint. Our could I paint it with latex. What do you think???????PS I have started adding photos to the gallery under Road Trip.
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 03-10-2006, 07:00 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Hey, Kirby!
I haven't done anything with my ceiling yet, so I'm not speaking from experience.......
I doubt that the popcorn paint would be very satisfactory. Even in a tall ceiling bus, there are too many things (like hands) that seem to be attracted to the ceiling.
One thing that might work is the fiberglass sheeting that they sell for bathroom walls. It has a textured surface, and it bends pretty well, too. It ain't cheap, though, at about $40US locally.
Of course, wood is a texture.... ;)
Eric von Kleist is offline   Reply With Quote
Old 03-11-2006, 12:15 AM   #3
I have thought about texturing the walls. I would mix up some drywall mud powder with cheap latex paint instead of water. Of course it would probably need to be thinned with water to spray properly. To protect hands, heads and anythign else that hits the ceiling I would use an oragne peel texture. Of course this is my idea and the decorator (wife) probably has another.
busone is offline   Reply With Quote
Old 03-11-2006, 07:27 AM   #4
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
I was thinking of a lite texture. Just to off set all the screws.......What kind of texture would stick to metal?? That stuff in a spray can get hard I thinking that would be the best.
Old 03-12-2006, 09:36 PM   #5
Getting it to stick to metal is not a big problem. I have seen many basements where they sprayed texture right on the exposed duct work. The problem in a skoolie is the metal vibrates like crazy. That is why I am considering mixing latex paint in with the texture. If the powdered mud is too thick I will just use latex paint. If it is not thin enough for the sprayer to handle I can add some water.
Old 03-12-2006, 10:55 PM   #6
the_experience03's Avatar
I don't know how well joint compound would hold up on a roof, but when we did the walls on our stairway in the house we took a rather easy approach. We took joint compound and put it on board so we could dab it with a big, heavy bristle paint brush. We would get a little on it, and then tap it against the wall. After a large enough area was done we LIGHTLY dragged a big putty knife over it to take out the points. The end result was a neat, cheap texture that was safer to skin than popcorn paint. Maybe it might be worth trying on a piece of sheetmetal and just driving around with it....see how it holds up?
Old 03-13-2006, 10:45 AM   #7
vonslatt's Avatar
I mixed the paint for the outside of my roof with ceramics:
http://www.hytechdistributors.com/
While I'm yet to be convinced as to it's effectiveness as an insulator it does give the paint a nice sandpapery finish and it makes it tougher. It's a good non-slip surface too, keeps me from falling off the roof.
There are textured wallpapers that you could apply to the ceilig and paint, I'm planning of something like this:
http://www.hgtv.com/hgtv/rm_walls_other ... 62,00.html
http://www.creativewallcovering.com/art ... ilings.php
Cheers,
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 03-13-2006, 02:00 PM   #8
Year: 1985
Rated Cap: 60
I looked at some of that textured wallpaper. It is very interesting, and very pretty. I particularly like the kind that looks like old tin ceilings.
Fortunately, I'm nowhere near ready to start on my ceiling, so I am going to be thinking about this a lot before summer starts.
Old 03-13-2006, 05:14 PM   #9
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Well I got some of that texture in a spray can and tried it. When it's dry you have a hard time sanding it off. I think at this point I think thats what I going to do.I let you know how it turns out...I got to try something just leaving it plan is not for me.
Old 03-15-2006, 07:25 AM   #10
Year: 1985
Rated Cap: 60
One thing that I am thinking about, although it may be prohibitively expensive, is that copper foil that they use for roofing. Mostly it's used for flashing, and it comes in rolls about 10 inches wide. It's not very thick, so it probably shouldn't be used in high traffic (hands on ceiling) areas, but it would make a nice accent in places, perhaps.
The stuff costs many American dollars.
Ceiling lights tomas_maly Conversion General Discussions 8 05-30-2013 10:02 PM
Carpet on ceiling Soundman1 Conversion General Discussions 12 08-04-2012 02:28 PM
Mesh ceiling Kathy WI Conversion General Discussions 17 06-04-2012 04:34 PM
Ceiling ventilation fan Atridox Short-Bus Conversion Projects 2 08-02-2011 02:12 PM
Anchor in ceiling AmyThompson Conversion Tutorials and How-to's 2 12-10-2010 10:39 AM
