Old 10-07-2009, 06:05 PM   #1
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
That topic about grounding an inverter?
Here are some pix of what happens to a bad chassis ground...
Ob1 is offline   Reply With Quote
Old 10-07-2009, 07:43 PM   #2
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
Re: That topic about grounding an inverter?
I havent gotten to the electrical of my bus yet so I havent studied much on the subject...can you tell me a quick bit of what this is about?
ramairws601 is offline   Reply With Quote
Old 10-07-2009, 08:36 PM   #3
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
The original question was whether to run a ground cable to the battery from the negative post on an inverter, or just connect to the chassis. I had made a point about possibly unstable connections using the body/ground circuit.
Those pix show what can happen when the ground leg isnt stable. Who can check every chassis ground connection? Leave the chassis ground for running lights and car stereos, hook the high amperage stuff up cable-direct.
Old 10-07-2009, 09:06 PM   #4
Chassis: C60
Rated Cap: 59
Originally Posted by Ob1
Those pix show what can happen when the ground leg isnt stable. Leave the chassis ground for running lights and car stereos, hook the high amperage stuff up cable-direct.
Yes, I agree. I have always ran ground cables back to the battery on something of a high amp nature. Thanks!
Proper house battery grounding & fusing roach711 Electrical, Charging and Solar 9 01-12-2012 09:55 AM
Grounding shore power to the skoolie's body. kc_4_jc Electrical, Charging and Solar 13 07-04-2011 03:35 AM
Grounding the inverter question ezbme Electrical, Charging and Solar 30 09-16-2009 05:55 AM
Off Topic Economics frank-id Everything Else | General Skoolie Discussions 2 03-09-2008 08:14 PM
I was wrong about AC grounding! Chassis should be grounded Eric von Kleist Conversion General Discussions 1 09-06-2005 09:32 AM
