Old 07-27-2015, 05:02 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
The easy way to insert great stuff
ID:	7991 ignore the great stuff behind the can
Zephod_beeblebrox2 is offline   Reply With Quote
Old 07-27-2015, 05:06 PM   #2
Chassis: Genesis
The problem with that is that Great Stuff *requires* moisture in the air to set. If you take the panel off after a time, you will find a layer of solid great stuff with a horrible liquid center. Previous threads have discussed whether or not the liquid was corrosive.
In my own experience, I have learned that Great Stuff does /not/ set or behave right in thick or enclosed areas. Makes a terrible mess.
Timelord is offline   Reply With Quote
Old 07-27-2015, 05:49 PM   #3
Year: 1994
Engine: 466dt
Rated Cap: 59
Yeah. Daptex is appalling garbage. Wrecked paint, dribbled and after it set, blew away as a powder.
Great stuff is a bit better. I've put Styrofoam behind the panel so I'm trying to fill the gaps. If the great stuff doesn't work, I won't buy more.
I'm almost finished with the internal construction. Been fighting a cupboard door all day!
Old 07-27-2015, 05:59 PM   #4
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Don't do it like that! There is moisture in GS and it will cause trouble, plus there's probably already bs like fiberglass n **** that will mess it up. If you want insulation in there, you're gonna have to take off the skins.
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 07-27-2015, 07:39 PM   #5
Year: 1994
Engine: 466dt
Rated Cap: 59
No fibreglass. One side is an aluminum panel I'd installed earlier. The othger side is a heavily painted galvanised steel panel I also installed. There is some breathing space there. I'm not greatly impressed by great stuff.
Old 07-27-2015, 08:19 PM   #6
What Tango said about Great Stuff needing air to cure is true. It works good to seal up exposed cracks but isn't good for back filling hollow areas. I call it "So So Stuff".
Drifting a bit, While serving as Range Master at the local Police Academy, One of the instructors got aggravated because the Cadets kept spilling the sand out of the weapon clearing tubes when they set them up. He "solved" the problem one lunch hour by topping off the upper third of the clearing tubes with Great Stuff so the sand wouldn't spill out. Needless to say, when the Cadets came back from lunch and loaded their weapons, not a one spotted the gooey foam in the tube and like good little Cadets did what they had been taught to do--end of range day. That particular Commander has since retired and now is a member of the City Council. Just figures.
Old 07-27-2015, 08:36 PM   #7
Year: 1994
Engine: 466dt
Rated Cap: 59
I'm hoping it's going to dry. If not, no matter. I'm not buying any more of it.
Old 07-27-2015, 08:39 PM   #8
Rated Cap: 40 Prisoners
Just to add to the previous post the guy over on the Wanderlodge
Owners Group used the great-stuff in his kick panels on his Dodge
pickup and in 18 months is now looking for a new cab for the truck.
The great-stuff caused all the enclosed places it was installed to
rust thru in the Florida humidity. He was trying to cut down cab noise.
Old 07-28-2015, 08:44 AM   #9
cullengw's Avatar
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
cullengw is offline   Reply With Quote
