Old 07-24-2018, 10:21 PM   #1
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
These Windows!!!
First off, I do not like the looks of busses that have RV windows in them. I really like the look of skoolies that have bus windows in them. I am going to get rid of a few, but plan on keeping most of them. I am not full timing, so I don't care about heat loss.
Has anyone ever bought replacement bus windows and put in new bus windows? Or do I just need to work with what I have?
I'm sure not, so I need to fix what I've got...
They used to leak like a sieve.
I used Lexon to seal the gaps between the aluminum window frames and the steel on the bus. But I still have a slight amount of leaking.
Each piece of glass has a a black piece of rubber between the glass and the aluminum frame. There is a separate piece on each of the four sides of the glass so it is not a continuous gasket around the glass. There is one on the inside and one on the outside.
This is a pic of the inside window. This rubber doesn't go to the end of the glass so water gets in the corners.
I circled the black rubber thing and drew an arrow to the spot where water comes in.
So now, should I use silicone to seal the glass to the aluminum frame?
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
https://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
