Old 03-01-2018, 01:17 PM   #1
Engine: dt466e
Things to do before roof raise...
I guess it only makes sense to raise the roof before starting most other projects, if not all. I've removed the seats, gotten rid of the loose rust and went over it with rust converter and oil based paint. Next im going to remove all the inside skins.
What could one do before a roof raise. Just trying to be more constructive.
adic27 is offline   Reply With Quote
Old 03-01-2018, 03:04 PM   #2
Robin97396's Avatar
Apparently having the pneumatic riveter is a big bonus.
If you've got your hat channels and sheet metal all worked out you just need an accurate jacking system, good weather, a few extra hands and a little luck/skill mixture.
Sounds like fun.
Robin
Nobody's Business
Old 03-01-2018, 03:48 PM   #3
Have you removed your interior ceiling skin and insulation? Do you plan to?
Old 03-02-2018, 10:02 AM   #4
Engine: dt466e
Not yet but will be removing both. Thats the next thing im gonna do. Have to finish converting the surface rust on the floor. Got half the floor done.
