Old 04-19-2019, 09:59 AM   #1
This has the space that I'd like in a bus
https://nwbus.com/inventory/transit-...it-bus-t48199/ This has the space that I would like in a bus. I am not sure if I would like the cat c7 engine. It is taller than many transit busses I have seen - has 3 steps up like most skoolies. I sent them an email to ask about the length and what kind of transmission it has. There are no storage bins on this but it is tall enough to install my own...I think I am in love! One thing I especially like is that if you are standing up, you can still see outside - you don't have to kneel down to see. That is the main reason why I would raise a roof in a skoolie. Would appreciate your comments on this kind of bus - what are the right terms to use to describe it...if it had a cummin 8.3l with an Allison 3060...and were a few years older (outside of smog regs)..and at least 37 (ideally 40) feet long it would be perfect
pengyou is offline   Reply With Quote
Old 04-19-2019, 09:37 PM   #2
Would this bus be called a transit high step? I wish I had the nerve to drive a 102" bus
Old 04-19-2019, 10:08 PM   #3
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
The only problems with the c7 is it is a parent bore motor so it can not be rebuilt in frame and had some issues so that it was considered less reliable than its predecessor the 3126e. The adept ape on YouTube has lots of Cat info.
The transmission will likely be either a b300 or b400 allison which is very similar to the md3060 but heavier duty. The gear ratio of the differential and if 6th gear is unlocked are important questions.
Ted
Old 04-19-2019, 11:21 PM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I would weigh in that the parent bore issue is by far not the main issue.
The parent bore issue actually isnít a big deal in my understanding, what is a big deal is the emissions stuff and possibly the HEUI system.
Adept Apes videos break it down pretty well...
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 04-20-2019, 11:21 AM   #5
I was just reading, on another forum, that CAT has come out with some "fixes" for the common HEUI issues.
Some upgraded internal parts and a HEUI oil filter.
Old 04-20-2019, 12:09 PM   #6
I know there's an oil line upgrade that includes adding a filter to prevent that nightmare injector failure.
Roll Your Own Build Thread
