Old 12-27-2017, 05:33 PM   #11
Robin97396's Avatar
If you need heat shielding tiles on the front of your bus, I'd sure like to go for a ride with you.
Robin
Nobody's Business
Old 12-27-2017, 08:20 PM   #12
Chassis: Saf-T-Liner MVP ER
I wouldn't mind them on the roof
Steve Bracken
Build Thread
Old 12-27-2017, 08:42 PM   #13
Robin97396's Avatar
Well, that doesn't sound as fun.
Robin
Nobody's Business
Old 12-27-2017, 08:46 PM   #14
According to my research, those silica tiles originally cost NASA $10000 per sq ft.
Back to Home Depot it is then!
Steve Bracken
Build Thread
Old 12-27-2017, 09:24 PM   #15
Robin97396's Avatar
Yeah, it sounds outrageous unless you're the one trying to reenter the atmosphere. The pucker factor alone would make those worth $10000 per sq ft.
Sounds like that contract didn't go to the cheapest bidder.
Robin
Nobody's Business
Old 12-27-2017, 09:51 PM   #16
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
I was on the GSAXcess website a few days ago at work, and they list surplus Shuttle tiles for sale to educational entities. No prices quoted, but if schools are bidding on them I can't imagine they're too expensive. Apparently each tile is unique, for one specific location only. Be the first skoolie owner to have his shower covered in Shuttle tiles!
Old 12-27-2017, 10:12 PM   #17
Robin97396's Avatar
That sounds lots more reasonable.
I was thinking heat tiles covering the outside of the bus might get kind of heavy, but it would definitely look unique. Probably would save the bus during any reentry too.
Robin
Nobody's Business
Old 12-27-2017, 10:23 PM   #18
The Wiki says that NASA were giving them away. They had 7000 tiles and could be had by educational institutions for the cost of shipping ... One tile per institution limit.
Steve Bracken
Build Thread
Old 12-28-2017, 07:02 AM   #19
Originally Posted by BlackJohn View Post
No roof insulating for me on my 20 year old metal tent. I like the stock look and despised the work involved never mind the mess involved. Wanted the bus useable asap so can put up with some heat loss by throwing another log on the fire. Summer, I look for some shade for the afternoon sun and only drive thru the night when cooler.
I'd never live long enough to make that insulting work out for me and when this bus is done, it becomes a parked hunting and fishing camp.
All up to the individual depending on your preferred climate.
I never expected to have the warmth of home or sustained cooling when hot but it ain't too bad.
I need to insulate my carpenter bus somehow.. in florida summer I sit in the driver seat with 65,000 BTU of A/C. and the only place thats cool is where my dash vents are blowing.. in winter as I have found out this week.. I had every heater on high driving around in 0f yesterday and I was still cold except for near the heaters.. (I know laugh now you in canada seem to dig this below zero crap)...
I love the stock look too.. I may just have to install another air conditioner and more heaters in that bus to maintain comfort.. lol..
Old 12-28-2017, 07:57 AM   #20
New2Skool's Avatar
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
I don't know how to prevent this delta temp difference in our skoolies.
I did a roof raise and spent a good amount of time trying to think of a way to prevent this heat lost avenue.
Other than physically spacing the skin from the ribs which doesn't seem like a very good idea.
The only other option, I found was insulating from down and inside of the ribs themselves to try prevent the heating from both coming in and going out through the ribs.
I had to consider the temp differences of all northern Minnesota season changes that are yesterday -39 F and the height of August 97 degrees with about 80% humidity.
My conclusion to try combat this law of nature was to buy, cut, install 1x2 inch cedar boards and mount them directly to the ribs to suspend the interior ceilings. The walls are slightly better with 2x2 pine mounted to the ribs giving me about an inch more space for poly spray insulation.
The ribs will have about 3 to 3.25 inches of insulation space while the roof has about 3 inches. Not the most ideal ratio per surfaces but, it will sure help prevent this temp variance.
I also had to come up with a plan for electrical and plumbing lines.
To prevent the temps from impacting both utilities, I created to internal channels on the inside of the insulation barriers. The first is down low under the seat rail and the second is up above the roof / window bulk head. They consist of a mounted layer of plywood with electrical wired on the upper half and plumbing mounted on the lower half.
Another big part of this utility channel idea is post construction accessibility. In order to achieve this, I will leave small access points in roughly every room or section of the bus. Once the utility lines are completed, I will board over the channels and leave access areas secured by basically screwing small hatches or covers that can be unscrewed later to provide access. I have seen a lot of very nice buses and many very smart folks run utilities and cover everything very nicely, complete framework and start finishing work just to realize they forgot internet cables or that they needed another outlet and suddenly, this beautiful finished skoolie has a plastic sheath running along the wall just to provide a power or water supply line to another area of the bus.
So, in short haha. My cold weather and blistering heat skoolie will have the best insulation envelope I can create with all utilities running inside of that envelope with post construction access. Hopefully both of these concepts will prove to be helpful in the long run of my rig. And honestly, I have no idea if they will but, the concept is sound.
D.L. Jones III
"The Independence"
98 International
New2Skool is offline   Reply With Quote
