Old 11-25-2014, 02:09 PM   #1
Threaded rod to mount tanks
Hello Everyone! I see a lot of people using threaded rod to mount their tanks. One of my friends' buses locally used it too, but I couldn't figure out how it was mounted and they bought the bus previously converted. I was wondering how people do it. Do you run the rod up through the "studs" underneath, into the floor of the bus and support them via a large washer on the inside of the bus?!? The "studs" on the underside of the floor of our bus are boxed in steel, so I can't just thread a rod through and put a bolt on it easily.
Here's some example photos of what I am talking about:
GoneCamping's bus
Our Friend's Bus (Rotten Ride on Facebook)
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 11-25-2014, 02:34 PM   #2
Re: Threaded rod to mount tanks
Threaded rod works fine if you remember a couple of things. If say, 1/4" rod looks strong enough to do the job, use 3/8" instead etc as the working diam of threaded rod is less than a similar size non threaded rod. Also be sure to use either nylon locker nuts or a pal nut along with each nut as threaded rod loves to unwind , Jack
Old 11-25-2014, 08:34 PM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
I have my 50 gal Veggie oil tank mounted like the last few pics-thru the frame. (Actually, the smaller outriggers holding up the floor off the main frame.) I'm using 6 pieces of 3/8" GRADE 5 threaded rod-ordered from Fastenal. Home Cheapo threaded rod is probabaly grade 2 or 3.( But unsure even at that.)
I pulled the tank down for cleaning + checking if the mounts are ok after 3 years--everything looked just fine.
Old 11-26-2014, 04:21 AM   #4
first picture of the SQ tubing can crush over time, the others look good, as Trunt said go with atleast 3/8-16 rod, McMaster Carr also sells it, Grainger and Fastenal
Old 11-26-2014, 06:00 AM   #5
Year: 87
Engine: 366/Allison
I think you're asking what holds the allthread at the top end. I used a 3/4" or so holesaw on the side of the 2X4 "joists". Allowed me to get a heavy washer & nut on the upper end, inside the joist.
Doug M is offline   Reply With Quote
Old 11-26-2014, 01:46 PM   #6
good idea
Old 11-30-2014, 03:59 PM   #7
Thanks for the tips guys!
This is an interesting way to do it. The bus of my friends had no holes in the joist for access. Must have went all the way through the floor.
WVO Powered!
Where to mount propane tanks vega12 Conversion General Discussions 43 10-19-2018 01:27 PM
Roof Racks/Deck... Side mount vs. roof mount? TygerCub Conversion General Discussions 37 08-14-2018 07:57 PM
plastic drum threaded bung fitting help needed bansil Plumbing, Water and Waste 10 03-12-2014 04:01 AM
How to mount tanks underneath? Diesel Dan Plumbing, Water and Waste 3 12-14-2009 11:28 AM
Propane tank mount & waste tanks installed... GoneCamping Conversion General Discussions 0 11-05-2006 10:30 PM
