Old 11-17-2016, 03:33 AM   #1
Engine: CAT3126b
Rated Cap: 64
Tint, metal wall, and the mysterious port
Hey guys!
I finally got some time off work to work on my build. I started working on Sunday and have finalized my basic idea and set to it. I got the seats out, the old ceiling stuff down, and stuff ready to start building.
Question 1: window tint
What kinda tint did you use? I have been looking at it and want to tint my windows for privacy reasons as well as thermal reasons. I was thinking like 5% VLT but what did you guys do? What kind of finish when viewed from the outside? Mirror? Green? Black? What do you think?
Question 2: metal walls
I have the side walls all unscrewed but I can't get the interior skin off. It's free on three sides but the top side is still on there. It's like folded back over a lip or something. Is there a trick to that or just get some gloves and apply some M x A and hope for the best?
Question 3: the mysterious port.
I found an odd plug thing on the front dash by the door that looks kinda like an Ethernet port had a baby with an USB. It has a small red blinking light when the bus is off. What is dat?
Question 4: where might be an idea to source emergency roof hatch parts. I may have yanked on the hatch a little harder than I meant to when it was in vent mode and broke the hinge plastic part.
I'm super grateful for everyone's comments and how to posts so far. This really is a kick @ss community.
Keep turning wheels.
Alpha4005
Alpha4005 is offline   Reply With Quote
Old 11-17-2016, 05:20 AM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
They're probably tack welded under the windows. Pop the windows (which will also make tinting easier), and break the welds or cut below
Captain Obvious on deviantArt
Old 11-17-2016, 05:31 AM   #3
Carytowncat's Avatar
That little port is an obdll connector, or on board diagnostics. It is how you connect to read codes, sensors, etc.
Old 11-17-2016, 05:51 AM   #4
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
If its not an ODBII port, pictures might help.
Old 11-17-2016, 12:28 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
I've been very happy with my SolarGard tint film. FYI about film and back lighting: even if you do 5% VLT "limousine" film, at night when there are lights on inside a person viewing from the outside will be able to see through to some degree. Silhouettes at the very least. It'll probably be a good idea to clarify what "privacy" means to you as far as lighting conditions and acceptable outside-to-inside view.
