Old 08-16-2007, 07:06 PM   #1
1 of a kind's Avatar
Year: 1961
Coachwork: Chevrolet of Canada
Chassis: Chevrolet Apache 30 (stock)
Engine: 6 banger, 4 speed.
tip to save you gas...
Hey guys, thot I'd share with you all a tip to save you on your skoolie gas usage. Easy to do. but does take a bit of time. took me 4 hours to remove some 46 years of dirt built up from in the frame rails and other "hidy hole"places. I couldnt believe the pile of gravel and such that was hiding . Also doing this will add years of life to your bus... and thats always a good thing.
1 of a kind is offline   Reply With Quote
Old 08-16-2007, 08:00 PM   #2
swinada's Avatar
Re: tip to save you gas...
where exactly did you find all of this? Sand box for the kids
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 08-17-2007, 07:16 PM   #3
Year: 1961
Heyyaz...I found 1/4 of that pile, on top of the gas tank, between it and the floor. all the rest was in the frame rails and tie downs from the bus body to the frame. amazingly enough, no real signs of rust damage. seems just a bit of wire brushing and she be good enough for paint...
OHOH....my cat is eye ballen that pile of sand an dirt. best go and spread it out over the parking lot, before she turns that pile, into "her personal potty"
Old 08-23-2007, 11:50 PM   #4
Year: 1961
Well I'm glad my "tip" has helped some1...I know it seems kind of an obvious 1, but if there are others out there who are excited bout working "inside" the bus (like me), just may over look the "under"..and its a good way to closely inspect and evaluate the under carriage, either for damage or for running lines or cutting or what have you. Me personaly, I like everything to be neat n clean an painted. MAKE'R ALL PERDY
Max
Old 10-18-2007, 03:17 PM   #5
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I hope you're happy with yourself! You just screwed up a 50 year scientific dirt test with only four years left. Now they have to start all over!
I'm hungry!
You Gotta Let Me Fly
How to convert your bus and save thousands. coakes69 Conversion General Discussions 8 01-11-2014 09:08 AM
SAVE on LV Purses swinada Conversion General Discussions 3 06-14-2009 07:25 AM
OMG! Somebody save this from the scrap heap! TygerCub Conversion General Discussions 5 06-01-2009 12:58 PM
Where to save money? :( (vs expensive 'RV' stuff) nearhomeless Conversion General Discussions 11 05-27-2009 10:55 AM
Save Dem Feet Zen Ken Conversion General Discussions 2 02-28-2006 08:18 PM
