Old 03-27-2012, 08:47 AM   #11
Chassis: TE2000 FE
Engine: 5.9L Cummins
Re: Tire Pressure?
Look at the cfm as well as max pressure. if the cfm is real low then you will be filling tires for a long time. You would need somewhere around 6 cfm or more fore tires, and even then if you were filling an empty tire it would take awhile. Also most air tools require 4.5 cfm or more to operate at full capacity.
Chuck
cschlessman is offline   Reply With Quote
Old 03-27-2012, 10:02 AM   #12
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Tire Pressure?
just put 100 psi and be done with,,,,same old B,S about the tire pressurs just put it in and move on,
keith is offline   Reply With Quote
Old 03-27-2012, 07:29 PM   #13
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Tire Pressure?
If you got a bus with air brakes, you could use your bus's air compressor (bus running). Mine pumps to 120, then starts pumping again somewhere at 90 + psi. You could just put the air chuck on the tire for awhile until you stop hearing air flow(& then wait some), and you'd probably be a 100 psi. Yes, you should use a gage, but you could get away without one. Tires cold.
Old 03-28-2012, 09:06 AM   #14
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Tire Pressure?
On all tc2000 buses there are two air tanks under the driver side, and one in the rear of the bus over the rear,so go back to the two tanks on the front an pum into the low tank on the bottom, by takeing the air drin pit cock off .u will still need the drin plus an air hose fitting,,if u don't under stand this,i will send u a picture.....gezzzzzzzzzzzzzzzzz
Old 03-28-2012, 09:49 AM   #15
Re: Tire Pressure?
When you add a tee and so forth to the tank,- along with a quick coupler for air... only use the high quality steel american quick coupling fittings, not the cheap harbor freight brass stuff. Sometimes one bump and the harbor freight stuff will just break. I have used the american quick coupler ends for the last 30 years, and those type of fittings can be bought at harbor freight also.
I was reminded of the harbor freight stuff breaking when i couldnt find a american quick coupler for my staple gun hose, so i had some of those brass ends from harbor freight - which i dont use... and when i dropped the stapeler, the harbor freight fitting just broke in half....
Old 03-28-2012, 01:38 PM   #16
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Tire Pressure?
right on 49,but some of them at lowes or home depot are crap too ,so paid for the good one's
Old 03-29-2012, 05:24 PM   #17
TygerCub's Avatar
Engine: Detroit
Re: Tire Pressure?
Pictures are worth a thousand words! Any images you have will be a tremendous help. I know where my large tank is, but am not sure about any smaller ones (if, indeed, there are any others on a Genesis). The large tank has 3 fittings, though. Might be worth doing instead of trying to mess with the portable air tank.
Old 06-23-2012, 03:18 PM   #18
crazycal's Avatar
Re: Tire Pressure?
The label for my Genesis says 120 psi cold front and 90 psi cold rear.
I'm hungry!
You Gotta Let Me Fly
Old 06-23-2012, 05:30 PM   #19
Re: Tire Pressure?
you should weigh your bus and have air pressure corresponding to the weight on the charts...
Old 07-19-2012, 08:01 AM   #20
bapos's Avatar
Re: Tire Pressure?
Having worked in the commerical truck tire biz for a few years Ill chime in on this one. This by far is THE MOST IMPORTANT aspect of tire care. This affects the drive, feel, pull, fuel consumption, and wear of the tire. There is not a single answer to this question as to what you should run but heres what i would suggest.
1) look on the side of the tire. It will contain a load range on it. This will contain information as to how much load that tire can handle SAFELY.
2) it should give a max capacity at a given psi. You can use this but the ride will be a lot stiffer and jarring.
3) take a look at the makers website for that particular model of tire. It usually contains a wieght to pressure chart. Experiment with pressures (check when cold only) to see what you like. As others have mentioned above a typical pressure will be around 100 psi for all. It may vary 5 to 10 psi typically for what people like.
As for compressors most of those will work but you will work them to death. The holding tanks are very small. Yes they will work but if your just adding pressure it wont take that long but if its totally flat your going to be there a while.
Here is my school bus conversion thread http://www.skoolie.net/forum/viewtopic.php?f=9&t=10282
Pics of my conversion @ photobucket http://s18.photobucket.com/albums/b1.../School%20Bus/
Air pressure tank leak down bapos Mechanical and Drivetrains 9 05-30-2011 04:26 AM
pressure tank cheezypsnookle Conversion General Discussions 6 04-17-2010 09:52 PM
Air pressure to the gas pedal WHISPERS Conversion General Discussions 7 11-12-2008 09:52 PM
Correct Oil Pressure cooter Everything Else | General Skoolie Discussions 6 01-09-2007 01:10 PM
Tire Pressure gealto Everything Else | General Skoolie Discussions 4 09-12-2004 04:42 PM
