Old 08-09-2004, 12:26 AM   #1
tire reccomendations ?s
hi all, i have read the latest tire FAQS in the forum and i am still unsure of the best tire for my 1985 s1700 IHC 345 gas bus. it currently has 900x20 bias ply tube type tires. i want to buy new tires preferably radials. is it correct that i can put on 10/22.5
radials in place of the 900x20 tires on it. i know i would have to buy radial tubes also. i want to get more of a standard size tire on the bus as you can hardly find a 900x20 in my area everyone states 2 to 3 day wait so that would not be good for me on a trip if i should need a tire. also is there a better, cheaper way to do this any imput is apreciated. thanks jesse
jpatt is offline   Reply With Quote
Old 08-09-2004, 07:45 AM   #2
Vern1's Avatar
Engine: 345 IH gas
Rated Cap: 66 passenger
Greetings,
The 22.5's won't fit on the 20 inch rims.
You will have to buy a new set of Dayton AccuRide rims.
These are one piece rims and will run tubeless tires.
They will fit on the same spokes as the 20 inchers.
My bus presently has the 20 inch tube types with split rims.
I bought a set of 6 new AccuRide rims and am waiting for the dollars for new tires....
Here is a link to a page that shows the rims.
Mine takes part number F130391225.
http://www.hdpsales.com/accuriderims.htm
The whole set cost 64.00 to have them shipped from north Texas to central Texas via truck freight and they cost about 68.00 each with taxes added.
Hope this helps!
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
https://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 08-09-2004, 09:19 AM   #3
Steve's Avatar
I recently went from 8.25x20 to 10R22.5 on my IHC Loadstar w/ 345. The information I have found that if you want to keep the same size of rire when moving to radials you should go with 9.00R22.5 however the 10R22.5 fit under there just fine with lots of room, look great, and will increase your top speed a bit.
Old 08-17-2004, 12:54 PM   #4
Steve's Avatar
I've been driving the bus a bit lately, I just got new exhaust on it yesterday. I am finding that I am having problems making the left turns. I think the bigger wheels and tires may have made my turning radius increase quite a bit.
To the tire Guru's somewhereinusa Skoolie Conversion Projects 3 11-13-2014 12:29 AM
Tire Blowout arfisher83 Everything Else | General Skoolie Discussions 6 05-11-2009 12:04 AM
Tire Tread Elliot Naess Conversion General Discussions 3 12-01-2008 06:46 PM
Tire Protection? hoser Everything Else | General Skoolie Discussions 4 07-03-2008 11:22 PM
Eaton Rear axle lubricant reccomendations? JonCBrand Conversion General Discussions 1 07-13-2007 10:09 PM
