Old 08-06-2009, 09:40 AM   #1
Re: Tire sizes
11 or 11.00 = width in inches
R= radial
22.5= wheel or rim diameter, aslo the .5 denotes a tubeless tire, a 20,22 0r 24 would be a tube type tire.
Old 02-02-2011, 09:34 PM   #2
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
Re: Tire sizes
Anyone know the outside diameter of 8.25-20-10 or 9-20-10 tires? And the nearest size tubeless substitute?
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 02-11-2011, 10:34 PM   #3
sportyrick's Avatar
Chassis: F33695
Re: Tire sizes
I think I can say with confidence my 9:00-20's are 40" cuz I just measured them. If my memory is correct my 10:00-20's are the same and I tried to use an 8.25-20 in place of a 900 once and they are 2" difference. If it wasn't so damned cold I would go over to the other building and measure my bus and the 10:00-20's on it and make sure I am right. An 11R22.5 is the same height as an 10:00-20 but is an inch wider. Fact is we just compared a 24.5 to a 22.5 and then to a 22.5 low pro and each is 2" shorter respectively. sportyrick
Old 02-13-2011, 06:52 PM   #4
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Tire sizes
A 10.00-20's replacement is an 11R22.5 or 295/75R22.5
A 9.00-20 is replaced by a 10R22.5 or 265/75R22.5 (275/70R22.5 should also work)
An 8.25-20 is replaced by a 9R22.5 or 245/75R22.5 (255/70 should also work)
In all cases, the metric sizes are maybe 1" shorter in diameter with the same weight capacity and rim size. If possible, I suggest running 11R22.5's or 295/75R22.5's--these are the industry-standard Class 8 truck sizes and drt-common EVERYWHERE.
Also, Michelin is weird with 22.5" tire sizes: a 295/75 is a 275/80 to them. A 265/75 is a 255/80, a 245/75 is a 235/80. They are the same size, they just don't say so. (Don't look at me, I didn't come up with this cockamamie size thing!)
Jarlaxle
Skoolie sizes Les_stephs Skoolie Conversion Projects 4 09-26-2014 08:21 AM
rub rail types-sizes etc bansil Conversion General Discussions 7 05-28-2012 07:09 PM
bus sizes availible bansil Conversion General Discussions 3 11-25-2011 08:16 AM
Mixing tire sizes steers and drives kotflb Conversion General Discussions 6 06-18-2011 03:09 PM
SEA engine bell housing sizes frank-id Everything Else | General Skoolie Discussions 0 02-27-2011 10:29 AM
