Old 08-01-2019, 12:16 PM   #11
Chassis: IH
Originally Posted by wireguy View Post
Yea, I want no part of caps. I figure the cost of one roadside service to replace one would pay for the difference between caps and new, not to mention the inconvenience and even danger.
I actually wired up a Bandag plant in Yreka Ca in my youth. They told me they had some secret proprietary system that resulted in superior caps.
I've had good luck with recaps. The government wouldn't allow them if they were in any way unsafe. In many cases you'll get better quality control since *EVERY* recap is (supposed to be) thoroughly inspected, where new tires only like 1 in 10 gets checked. Reputable recap makers stand behind their tires - Bandag will replace any tire on which the tread separates.
The main thing that kills tires - recaps or new - is heat. That's a leading cause of tread separation on recaps and tire failures/blowouts. Low/flat tires flex more, generating more heat, which ultimately can lead to a blowout.
Old 08-01-2019, 01:02 PM   #12
Year: 77
Coachwork: Gillig
Engine: 855 Cummins big cam
Rated Cap: single axle
I live close to I-10 and I see the results of what heat does to caps every time I drive on it. Here in the Sonoran desert where I live heat is to be taken seriously.
wireguy is offline   Reply With Quote
Old 08-01-2019, 02:38 PM   #13
HazMatt's Avatar
Chassis: IH 3800, 8 window
Number One preventative measure to take is keeping the rubber properly inflated to manufacturer's spex.
I prefer flirting with the top-end sidewall psi rating: less rolling resistance, marginally better fuel economy, less heat generation.
Caveat emptor: may make for a lumpier ride, howeva...
Old 08-01-2019, 02:41 PM   #14
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
Are you sure that your Gillig uses 11R22.5 tires? That seems small for a heavy bus. What does your manufacturer's data plate inside say (it's the one that specifies the bus's tire sizes and axle weight ratings)? I use 12R22.5, as do many other Crowns and Gilligs. Do not go smaller, i.e. lower weight capacity; if you were to be inspected by DOT and they saw smaller tires, that would be A Big Problem for you.
I recently bought six Yokohama 104ZR for my bus to replace the Michelin XZE that were aged out and cracking - it's the only 12R22.5 made by Yokohama, and I'm very happy with them.
Old 08-01-2019, 02:52 PM   #15
Sleddgracer's Avatar
Chassis: still looking for my bus
I worked in a tire recapping business one time - I was surprised to learn that the aircraft industry had less blow outs on landing with casings that had been recapped once or twice than they had on brand new tires - I used to run recaps on my one ton on duals - specifically with the 'Suburban' tread - never had better traction in snow or ice before or since - I consistently got over 100,000 miles on them before they started 'losing their grip' - I was very often severely over loaded on the truck as well, and I've never been shy about pressing down on the gas peddle when I'm going somewhere - never did lose a band or have a blowout - the style of retread we used in the shop I worked at had thin rubber that covered all the scratch marks that were made on the casings during the process of removing the old rubber - they looked nicer to the eye than the Bandag types you see on larger vehicles because they don't cover the marks made in preparation
Old 08-10-2019, 08:33 PM   #16
Year: O4
Chassis: Chevrolet
Engine: 6.0 Gas GM
Rated Cap: 26 passenger
If you do a lot of OTR driving and little cold weather driving you might even consider Super singles on the rear. You would need 455 22.5 not the 445 22.5. You would also need 0 of set wheels, they ride great, Carry a big load with less weight.
They suck on ice though.
Smokinjsbbq is offline   Reply With Quote
Old 08-10-2019, 10:01 PM   #17
Year: 77
Coachwork: Gillig
tires
OK, I just bought 6 new Ameristeel tires 11RX22.5 for about 338 each, 259 for mounting and balancing and 49 for tire disposal. There was 300 difference between new and caps for the drivers and for 300 I'm going with new all the way around.
There is this other tire company up the road. New tires, used tires, truck tires, farm equipment tires. My wife called them twice and told them what we wanted. She is real nice and professional. They called back after the first call and she reminded them that we were looking for six tires. "OK I get back to you." Never heard from them again. Business must be good.
Old 08-10-2019, 10:01 PM   #18
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by sportyrick View Post
I just bought new steer tires, Michelins 1100x22.5 at Petro Truck Stop and it ran about $1300 if you want the best, otherwise pick your favorite brand, HO-CHI-MINS are ok for rear but I want good tires on front
And right you are... Some examples of heavier vehicles blowing steer tires...
And this is what you do to keep control in such situations...
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
Old 08-11-2019, 10:47 AM   #19
Engine: 6-71TA
Rated Cap: 90
Be careful purchasing tires that seem to be a good deal. Especially, from vendors who don't cycle through much inventory. It is likely the tires are of old stock and could be a few years old, so check the tires date code.
The Bridgestone tires on my Crown have like new looking tread but the tires are more than 12 years old according to the date code and the School maintenance records which showed date of purchase (this was another way I confirmed it was used as a backup Bus). I noticed very small cracks in the sidewall from age but that was after we drove it back 1800 miles from CA.
We plan on replacing the tires after the conversion is completed.
GWRider is online now   Reply With Quote
Old 08-11-2019, 11:02 AM   #20
Aye, my truck has 15 year old tires that look nearly new. Always check dates.
Roll Your Own Build Thread
