Old 10-13-2016, 11:56 PM   #1
Question To all insulation experts - Thermal break
Hi.
So after long research it seems to be needed to somehow insulate between the metal ribs and whatever you install on top of the ribs to avoid thermal bridge between the rib and whatever wood you use, the idea is to minimize the thermal transfer that metal has and avoid passing that as much as you can to the wood.
After reading many papers about house insulation in different countries and standards it seems to be necessary to leave a gap between the metal stud and the insulation and the idea is to touch as little as possible any metal stud so there is this weird cladding systems and brackets that you can buy for metal studs but the problem with the buses is that space is limited so I searched for a solution for limited space that you can install in between the metal ribs and the furring strips that I plan to install on top and I found this :
Thermablock
is meant to be installed on top and it supposed to give better performance than most products and is compresible so it can be use in like a sandwich setup for lack of another word.
Please keep in mind that I'm driving my bus to Alaska in winter with the family so -30c or lower could be possible so any idea to insulate better is welcome and please do not try to convince me to not do the trip because I'm not going to listen.
The bus will be sprayed with injected foam after the frame is up and then cover with some plywood or other kind of wood finish.
so a couple of questions :
1.- what do you think about thermablock, could it help ? any other product you know ?
2.- what about an air gap in between the ribs and the frame ?
3.- should I use stainless steel self tapping screws instead of just steel ?
Any other suggestions ?
Thanks.
pepepito is offline   Reply With Quote
Old 07-18-2017, 08:05 PM   #2
Wondering the same
Did you ever get advice on this anywhere? I've especially been wondering about the Thermablock, though I'm not sure where to source it or how cost effective it is. Interested to know if you went with a totally different plan altogether!
Originally Posted by pepepito View Post
Hi.
Thermablock
Thanks.
Iron is offline   Reply With Quote
Old 07-18-2017, 08:10 PM   #3
I end up buying thermablock and I started installing it, I will upload some measurements after I'm done.
Old 07-18-2017, 08:22 PM   #4
Awesome. Where did you source it? Also what does it cost? Really appreciate your feedback.
Old 07-18-2017, 08:26 PM   #5
I bought it from the manufacturer acusticblok
Sent from my ONE E1005 using Tapatalk
Old 07-18-2017, 08:27 PM   #6
without adhesive 4 1/2 ft x 1.5 in x 0.40 is 7.47 US
