Old 10-25-2017, 01:27 PM   #1
To thin or not to thin? (Exterior Oil Paint Question)
Bought an exterior grade oil paint and was wondering if we should thin the paint before it goes on?
We are done sanding the bus, planning on Ospho-ing the rusty bits and sealing some of the looser looking seams before a full rub-down of mineral spirits. Just wondering if we should thin the paint?
Thanks.
McPuccio is offline   Reply With Quote
Old 10-25-2017, 01:39 PM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Where are you? What is the weather like? How are you applying the paint? What brand is it? What color is it? How thin is it?
Old 10-25-2017, 04:02 PM   #3
We're in Texas. Weather is pretty clear, but also like mid-50s. We're planning on rolling it on. Color is sage green ("coastal crush").
Old 10-25-2017, 04:19 PM   #4
Chassis: Saf-T-Liner MVP ER
Paint is usually thinned for spraying. If you are rolling it, it should be fine straight from the tin.
Steve Bracken
Build Thread
Old 10-25-2017, 05:38 PM   #5
Traveling
Rated Cap: '00
When I painted my bus, I power washed it w/ phosphate detergent, such as TSP.
Then sanded w/ 220 grit, some use deglosser liquid.
Quick wash, then wipedown with lacquer thinner.
Then primed entire bus.
Then sprayed w/ compressor powered HVLP gun from harbor freight (purple)
You's be wise to use hardener in your paint. Many who roll-on say they wish they'd sprayed.
Old 10-25-2017, 05:40 PM   #6
I will roll the roof, spray the rest.
Steve Bracken
Build Thread
Old 11-02-2017, 07:35 AM   #7
spenceronehalf's Avatar
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
Attachment 16909
How much hardener, Rusty? One can per gallon or something?
Sent from my iPad using Tapatalk
spenceronehalf is offline   Reply With Quote
Old 11-02-2017, 08:28 AM   #8
Traveling
Rated Cap: '00
No, not much at all. Just mix it it the paint you are spraying immediately in the hour or so.
Old 11-02-2017, 08:40 AM   #9
Engine: CAT diesel
cool. I'll just order one can
