I'm using rockwool in some walls. Interior walls especially since its completely fire proof and thus could help if such a calamity strikes. Its hydrophobic as well. Good stuff for certain applications.
Poly board will be used in the exterior walls and ceilings. I *MAY* do a bit of spray foaming, but I'm trying to keep this simple and cost effective.
"styrofoam" is about the cheapest foam board out there.
Any other foam board is more expensive.
Styrofoam and rock wool have almost identical R values per inch.
I was at Lowes comparing prices and the rock wool is 1/2 as expensive as styrofoam sheets per sq ft.
