Old 11-04-2009, 07:56 AM   #1
Seeria's Avatar
Toilet special needs
A member of my family has a mental disability with a few quirks. This requires a special toilet. A dry one.
Anyhow, I am hoping someone here has seen a toilet that has a dry bowl?
Never used an RV one so not sure how they operate. And my memories of the marine ones were they were simple handles you pumped to open a valve and allow water in after the biz was done.
Old 11-04-2009, 12:55 PM   #2
Re: Toilet special needs
I don't know what needs you are talking about, but don't the composting toilets work without water? And you could put a lock on the compost box so it could only be opened by you. Of course if you are a full timer, I'm not sure if the composting toilet is a good idea, but it might be.
crazyidea is offline   Reply With Quote
Old 11-04-2009, 05:41 PM   #3
Seeria's Avatar
First idea with the porta potty might work. I do want to connect it to a black water tank, since there is simply NO way this many people can do a compost toilet rotation.
They problem isn't her touching the water, it is the water accidently touching her while doing potty biz that hmm creeps her out. A quirk but not unusual for people with her disorder.
I'm not a plumber so will have to see what diagrams I can find to make a porta potty like that work with a bwt. Suggestions are always welcome!
Old 11-04-2009, 06:46 PM   #4
newbusser's Avatar
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
look into this also...
I believe it pumps dry after each use, but not sure.
Scott
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Old 11-04-2009, 09:12 PM   #5
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
most rv toilets i have used are dry until u fill the bowl with water and then flush ..it is a two pedal system one fill one flush
and can be used dry...it sometimes just requires alittle more scrubbing come cleaning time
cheezypsnookle is offline   Reply With Quote
Old 11-05-2009, 07:34 PM   #6
Seeria's Avatar
Thanks, folks! Will look into those.
Tailgate Nascar Special 1988 Blue Bird 66 Passenger garbemi Skoolie Conversion Projects 1 01-25-2013 04:28 PM
special thanks to smitty timbuk Everything Else | General Skoolie Discussions 14 04-03-2011 08:38 PM
Wanted: Bluebird TC Special Ed Bus tubing&adventures Classifieds | Buy, Sell, Swap 12 07-08-2010 09:06 PM
96 Thomas Vista Special Needs tour bus conversion DontWakeAislin Short-Bus Conversion Projects 3 11-23-2009 03:47 PM
special message for all skoolie.net members bdavis441 Everything Else | General Skoolie Discussions 14 07-18-2007 05:23 PM
