Old 08-07-2018, 07:36 PM   #1
Engine: 466e
Rated Cap: its Yuge
Tongue and Groove Ceiling questions
I am getting so close to working on the inside, i can feel it
Almost done with insulation, planning on tongue and groove on the ceiling, but wanted to run some thoughts by those who have done it.
1. Main concern i have is shrinkage/expansion of the boards. I am not living in the bus full time, just using occasionally, and it will only be heated/air conditioned occasionally. Has anybody had experience or problems with this?
2. I don't plan to use glue, just finish screws thru the tongue at an angle into the ribs. Any thoughts on this.
3. Planning to start at the center with 2 boards grooves together and a thin piece of wood serving as a tongue between them. The thought is that it would be easier to keep straight over just half of it.
Anyhow, any help or advice is much appreciated.
Thx!
MambaJack is offline   Reply With Quote
Old 08-08-2018, 08:24 AM   #2
Engine: 466e
Rated Cap: its Yuge
Also interested i most people treat the wood with polyurethane/stain after they install or before?
Old 08-08-2018, 08:52 AM   #3
I don't know how most people do it....and we didn't do tongue and groove, we did sheets of 5mm luan underlayment, so take this with a grain of salt. It was much easier to paint them before we put them up, and a heck of a lot less messy. Also, with bare wood, you'll be able to finish both sides of the wood if you want the extra protection from moisture, which IMO wouldn't be a bad idea.
Old 08-08-2018, 11:10 AM   #4
simonsteve's Avatar
Chassis: International 3600
I agree with finishing them before you put them up. I used a water based poly. I went from the driver side and up over to the passenger side. The curve is a bit of a pain, but I added furring strips to mine to make something solid to anchor to.1533744585797.jpg
simonsteve is offline   Reply With Quote
Old 08-08-2018, 08:08 PM   #5
tobeamiss's Avatar
Here's what I used and it worked out well. Each 8' plank is so light I could carry it balanced on one finger. I like the fact that it's thin and lightweight...
I used minwax poly/stain first. Started from the center and worked my way out. I have to say it looks really nice.
Here it is from Home Depot and then the finished product...
Sorry my pics aren't that great. If I remember, I'll take more tomorrow.Screenshot_2018-08-08-20-59-03-1.jpeg20180530_153025.jpeg20180517_151726.jpeg
oh yes she did!
http://www.skoolie.net/forums/f11/to...-it-16557.html
Old 08-08-2018, 11:20 PM   #6
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
The wood will absorb and release water more evenly if both sides are treated and it's less likely to get warped if it gets wet at some point. You have to cut it to the right length first if you want to be able to do both sides and all the edges which is why most people don't do it. I plan to.
2martins is offline   Reply With Quote
Old 08-09-2018, 08:29 AM   #7
tobeamiss's Avatar
You are absolutely correct. That's the way I did it. Every square inch of the plank was treated...ends as well.
I forgot to mention that the leftover scraps I have laying out in the yard, have gotten rained on all summer long and have not warped in any way. It's been an unusually rainy summer here too!! But they look as beautiful as the day I first treated them.
oh yes she did!
Old 08-13-2018, 07:27 PM   #8
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I used a preprimed tongue and groove. It's thick. I started at one side and just worked up and over. I got lucky that it fit like a glove. The picture looks like drivers side is higher, but it's not. Did the first 3-4 rows by myself until some help showed u. I added 2x2 to the side of the bus ribs to attach to IMG_20180722_081739.jpegIMG_20180711_203000.jpeg
Nick
Old 08-14-2018, 07:24 AM   #9
karrlot's Avatar
Coachwork: Ward
Rated Cap: 65 passenger
What method has everyone used to attach the T&G. Any problems with your choice?
Please check out my blog-
Follow the (lack of) progress on the Karr Family Kamping Bus Blog
Here is my woefully inadequate build thread:
http://www.skoolie.net/forums/f11/i-...bus-12296.html
karrlot is offline   Reply With Quote
Old 08-14-2018, 05:51 PM   #10
nanoplane's Avatar
Chassis: MVP
Engine: 8.3L Cummins Turbo
my ceiling is T&G knotty pine bead board. I use self drilling SS Lath screws one in the middle of the lower half of the board at each ceiling rib. I cut the pieces to length so the joint is at a rib and then have a screw between the planks lengthwise. This should allow flexibility for expansion / contraction without splitting.
To install the adjacent plank, I first fill the groove with henry's "crystal clear" silicone calk. to stop potential rattles.
Note: I'm not finished yet...
Pic:
--Marcel
Build Thread
nanoplane is offline   Reply With Quote
