Old 10-10-2014, 01:04 PM   #21
Re: towing with skoolie -
lets not get to generic sounding with 5spds
example: you can not tow an isuzu amigo,trooper,pup etc with the MUA5 4 down or rear wheels down, w/o disconnecting the rear drive shaft
this is due to a roller bearing on the transmission output into the t-case upon which the "main gear" spins (lay means terms and easiest explanation)
you will kill bearing, which will lock up and vehicle will think it's between low/hi range...not pretty with wheels locked up and smoke, easy fix :wink"
for folks with extra parts (2 different teeth counts and no vin differences)
ooopss long tangent with way too much TMI
back to regular programming and I need to check beef jerky
Old 10-10-2014, 01:59 PM   #22
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
That's why I stated "check with manufacturer." Not every 5-speed vehicle can be towed 4 down.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 10-10-2014, 03:45 PM   #23
manufactures don't always know...the Isuzu thing took years for it to come out...why?
no one towed them
they always did the towing back then...in the old days...Remember the 90's ?
Old 10-10-2014, 06:40 PM   #24
schoolmarm's Avatar
Year: 1985
Coachwork: Wayne Chaperone
Chassis: chevy
Engine: 350
I own a Isuzu Amigo and Isuzu and everyone I have talked to says "NO TOW". I can not find a single article stating that it can be done. Where is your info coming from?
schoolmarm is offline   Reply With Quote
Old 10-12-2014, 12:46 PM   #25
I said it couldnt be done, with out taking loose driveshaft (not typical of 99.999999999999999999999% of people towing one
and as for T-Case issues? I have rebuilt enough of them because of rust on said roller bearing, no oil from towing and general stuff like low range gear swaps, and swapping slip yoke rear cases for fixed yoke and even a dual case setup
Lisa and I have owned and used/abused Isuzu's off road for 15 years, even raced them for a few years
so Like I said...........YOU CAN NOT TOW 4 DOWN!!!!!! Unless you take rear drive shaft loose and ensure front hubs are unlocked or if you have drive flanges up front (gotta take them loose)
And I also have support of the BEST Isuzu mechanic in the USA at my disposal
When I say the best, I mean it...he was the first American to go to Japan to learn about them, and came back and trained every Isuzu truck mechanic to work on these things
If you need any OEM parts, PM me and I will get you in contact with him, he bought out several dealers when they shut down
ALSO check out Planetisuzoo.com it was started 10/11 years ago after we all gave up on 4x4wire, it's free and more Isuzu info is there than anywhere on the planet
Sorry for long rant
wifes DD Rodeo Sport
9" and 31's
my old Amigo
14 point cage and wicked
4th gear low range in the woods
middle of build, it was cold
tucked in tight to the corner
in flight
My DD
the Turtle 14 yrs ago
locked front/rear fu;; skid plate
Lisas race truck
3rd place, 7 trucks out of 42 in 3 classes finished...very brutal
Dont take the rant and drive through memory lane as me being mad or an ass...it brought back lots of memories thank you
Old 10-12-2014, 03:14 PM   #26
schoolmarm's Avatar
Year: 1985
Chassis: chevy
Engine: 350
I love my 1990 Amigo although I have no need to tow it. Wish more people were aware of what you stated because a lot of people would tow but don't know it is possible.
My Amigo was bought by me in 1994 and has been through 3 of my kids so you know it is a tough little ride. Other than routine maintenance it requires a starter about every two and a half years. Mine has the hard top and is silver/gray in color. It is a fun ride to drive and I LOVE IT.
Thanks for the info I will pass it along.
Towing a trailer with a Skoolie Hymnsinger Conversion General Discussions 4 03-04-2014 10:26 AM
Towing with your skoolie lornaschinske Conversion General Discussions 18 04-30-2013 09:37 PM
Towing... nearhomeless Mechanical and Drivetrains 9 07-23-2010 08:44 PM
Towing a car trailer behind a skoolie? waywardfool Conversion General Discussions 7 07-21-2006 07:41 AM
towing with 345 IH bdavis441 Everything Else | General Skoolie Discussions 12 02-27-2006 10:33 AM
