Old 09-28-2007, 01:21 PM   #11
Steve's Avatar
Re: towing with transit/tour type bus?
You see RVs pulling large trailers behind them all the time, I would think any bus would at least be better than those at pulling.
Old 09-28-2007, 03:00 PM   #12
Well you probably won't find a skoolie with much more power than a 5.9 in a TC2000
exactly... that's why i need to upgrade. honestly, it does pretty well with what i tow, but the non lockup transmission kills it and grades really drag it down. i'm pretty demanding of my tow vehicles, with a frequent amount of mountain driving. it does great on the flats, but going through the hills is not fun.
which brings me to another thing, BRAKES. even with brand new functioning trailer brakes on both axles, it can still be a little scary coming down steeper grades. i'm in desperate need of an engine or exhaust brake. all that combined with the other things i don't really like (ride, noise, etc.) it makes more sense to me to put the money torwards a completed transit bus conversion or (yikes) a conventional pusher RV with a C series cummins or something.
Aren't pull behind hitches rated at 10,000lbs max?
no, you can get hitches and ball mounts rated for more. do a google search for titan. it's a 2.5" reciever, rated for 15-20k. even the 10k hitches are capable of handling much more than their rating.
Anyway if you're asking if anyone here has any experience towing a trailer that heavy with a transit/tour bus you might not ever get an answer.
that's exactly what i'm asking. i figured most people here were skoolie owners, thought it was worth a try though. i'm going to ask on busnuts also.
You'd do better asking over on busnut.com or busconversions.com forums. They will probably discourage something that heavy.
The big issue is not so much the trailer weight as the tongue weight.
yep, ive been searching there a lot. i've read all about the engine cradle issues. i feel like the people discouraging it don't really know what they're talking about though, several people in a few threads gave solid engineering specs on the bolts, design, etc. of the cradle which indicated tongue weight should be no more of an issue than overall trailer weight. so, my main concern at this point is power.
I have an MC9, btw.
cool. i have my eye on an mc8, with the dana 4 speed manual and 8v71.
1991 Blue Bird TC2000 shell version
5.9 Cummins/AT545 Allison
The Wanderer is offline   Reply With Quote
Old 09-28-2007, 03:04 PM   #13
here's a picture of my current setup if anyone cares to see.
Old 09-28-2007, 04:07 PM   #14
the_experience03's Avatar
Huh...you have a stinger on the bus, but not on the Jeeps. Interesting.
Do you have air brakes or hydraulic? My properly adjusted air brakes almost have too much stopping power unloaded. They are the first thing I teach a new driver about in the bus...at 5 mph....in a parking lot....because otherwise everything wants to go through the windshield when they get on it like in a car. I would check the condition of the brakes first and foremost if stopping is really that much of an issue. An exhaust brake is going to be a fart in the wind on that bus. Without a lockup converter all you're going to do is make some noise and some heat with very little braking power. You could look into a retarder, but I believe the AT545's with the retarder option were slightly different. Someone else can probably clear that up.
Old 09-28-2007, 05:28 PM   #15
I stil can;t get over that wheelbase..
behappystupi is offline   Reply With Quote
Old 09-28-2007, 09:15 PM   #16
Legal length is state dependent. The lowest I've seen is 60 feet with 75 feet being the max. I would probably try and stay at or below 65 total if I was going cross country to keep the eyebrows down.
Old 09-29-2007, 12:39 AM   #17
i have air brakes, and they're in great shape. they work AWESOME when empty, like you said they'll throw you through the winshield. they work great with the trailer too, the problem is fade. trying to maintain a speed on a grade just heats them up too fast, and they don't recover. steep downhill grades in the mountains i have to keep it to 30mph or less when i'm loaded.
i think legal overall length here in NC is 70ft. i'm not really concerned about it though, if i get a ticket i get a ticket. price to pay for having the setup i want.
i posted this over on busnuts, and so far the response i'm getting is not positive. seems they feel like the 8v71 has enough trouble dragging the coach around, much less a heavy trailer.
back on the hunt i guess... i've got two RV's on my radar also. one with an 8.3 cummins and the other with a 3208 turbo cat. both built on bus chassis.
Old 09-29-2007, 03:22 AM   #18
BassnTruck's Avatar
Coachwork: AM-TRAN
Chassis: International 1853
Engine: DT466 210hp, MT643 trans
Rated Cap: 44
Wow I did not notice how short your WB was until I went back and looked. Well ya can bolt up an MT643 to your motor that has lock up and can get a retarder. I plan on getting an Jake break for mine. As for the power. You can crank that cummins to 1200HP if ya really want. But 350 will probably work just fine for you. But you will have to ditch your current trans since it is already being over taxed. I know some of you would have a hard time dumping a few grand into the motor since ya payed less for the bus in most cases but mild 5.9 will fetch a few buck on evil bay so ya can get most of your cash back out of it. Mine takes off from a stop and does pretty well down the highway but on the big hiss she is under powered. But I will crank up the 466 to about 350hp and I will be set.
BassnTruck is offline   Reply With Quote
Old GM Transit Bus - AUCTION - Asheville NC CHEESE_WAGON Classifieds | Buy, Sell, Swap 3 08-03-2014 04:18 AM
Midwest Transit GOOD or BAD? wmah Everything Else | General Skoolie Discussions 0 10-05-2009 06:06 PM
transit bus frames adamanderr Conversion General Discussions 1 02-23-2008 07:22 PM
How's This Transit Bus? runnysucklehose Conversion General Discussions 9 02-15-2006 09:24 PM
Going On Tour! Ralis Conversion General Discussions 11 12-09-2005 06:41 AM
