Old 08-29-2006, 09:19 PM   #1
eggman's Avatar
Trailer hitches??
I have read all that I can about trailer hitches. Went to three different stores to try to measure some receivers for mounting on my skoolie. However, I have yet to find one that will fit. Closest I have found is one for an import SUV, lexus or toyota I think. Only problem is that the mounting angle gets wider as it goes towards the front.
Does anyone have a part number or a manufacturer's number that has one that will fit a 95 IH bus. Measurements are 34 1/8" from outside to outside of frame, and 27 7/8" from between frame to frame.
On my skoolie, there is a 7" x 2" c-channel running from one frame to the other with the "c" facing up, and it has two huge tow hooks bolted to it. Is it a good idea to remove this "c" channel and bolt the hitch directly to the frame, or to leave it alone and use spacers between the over hanging parts of the hitch. I dont like the spacers idea.
Anyone?
Jeff
95 IH 72 passenger transit school bus w/ DT466 and 545 Allison.
79 IH Scout II/392 (0.030 over) Hamilton Injected/727/D300/Full size axles/36" Swampers/Lockers/OBA/38 gal Custom fuel tank, roll bar, tube doors.
eggman is offline   Reply With Quote
Old 08-30-2006, 04:38 AM   #2
eggman's Avatar
Where is here?
Jeff
Old 08-30-2006, 09:26 AM   #3
trentet's Avatar
Engine: INternational DTA 360
I also have an international
I have a 92 international and I wanted a class 5 reciever for it. It turns out that the 34 inch spacing on my frame is the same as the 2000 and later Ford F-350's and F-450 cab and chasis pickups. After looking around I purchased a Putnam class 5 reciever with a 15000 lb capacity and a 1500 lb tongue weight limit from hitch-web.com for $280 which was $150 cheaper than the Reese hitch that had a lower weight limit, and the Putnam came with a 2" reciever not a hard to find 2-1/4" reciever. here is a link to the hitch: http://www.hitch-web.com/proDescrip.asp ... 5245&OID=8
and here are some pics of my installation: http://www.skoolie.net/gallery2/v/Skooli ... ?g2_page=2
"Beer speaks people mumble" (lagunitas beer bottle)
trentet is offline   Reply With Quote
Old 08-30-2006, 09:37 AM   #4
I took off the tow hooks because they were bent to all hell. The metal that held them on was twisted badly. I just bolted the hitch to the frame rails. I perfer not to weld on them.
busone is offline   Reply With Quote
Old 08-30-2006, 01:04 PM   #5
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Trentet,
Lucky guy. Not 1, not 2, but 3 Emergency Exits.
The possibilities with floorplan layouts!!
Coma is offline   Reply With Quote
Old 08-30-2006, 11:14 PM   #6
trentet's Avatar
the better to escape with
Actually my bus was a dedicated handicapped bus so it had seating for 8 little kids and the rest was tie downs for wheel chairs. I guess there weren't a lot of handicapped kids in Humbolt cause it only had 12,000 miles on it. I have one of the emergency exits partly blocked by the combination bunk/bench seat, so it's not that usable but it's still possible to access.
Old 08-31-2006, 09:39 PM   #7
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
I used a Chevy pickup hitch and had a welder add extensions to the mounts.
I haul a fully loaded stock car trailer with it and it works awesome.
Firearm is offline   Reply With Quote
Old 09-01-2006, 02:02 PM   #8
vonslatt's Avatar
I used a step bumper hitch and upsized the mounting holes for 5/8" grade 8 bolts.
(the original 1/2" hardware is shown in the photo.)
More here: http://www.vonslatt.com/bus-body.shtml
Jake.
My 1989 Thomas Saf-T-Liner
vonslatt is offline   Reply With Quote
Old 09-02-2006, 07:27 AM   #9
eggman's Avatar
Thanks everyone for the replies. I knew there had to be a pretty much bolt on application out there somewhere. Will probably be using the SD Ford hitch.
Jake, I like the ease that your idea takes, but I think its a bit undersized for my application. Loooking to haul a 5500# Scout on a 17" flat bed trailer. I think the total weight is around 7,000#. Quite a bit more than a small car.
Again, Thanks everyone for the ideas.
Jeff
Jeff
Old 09-02-2006, 08:02 AM   #10
vonslatt's Avatar
The bumper/frame members on my bus are certainly good for +10,000 lbs but yes, I'd want a beefier receiver for that kind of weight, I'd probably just bolt on one of these forged pintle/ball combo hitches from Northern Tool.
http://www.northerntool.com/webapp/wcs/ ... _7808_7808
Jake.
Receiver hitches - how much should I pay? Diesel Dan Conversion General Discussions 11 06-27-2012 09:15 AM
trailer on bus Stuff Conversion General Discussions 11 04-18-2012 11:49 AM
Any clue what Hitches would fit an El Dorado THOR bus? wirelessguyNY Short-Bus Conversion Projects 4 09-03-2011 09:04 PM
Schoolies and hitches not legal? Train-train Conversion General Discussions 8 10-31-2008 01:45 PM
Trailer? We don't need no stinkin' trailer... Abbott Everything Else | General Skoolie Discussions 0 07-11-2008 01:16 PM
