Old 02-23-2008, 04:44 PM   #1
transit bus frames
what style frame do low floor transit buses use. it couldn't be the high heavy duty truck style like school buses??????
adamanderr is offline   Reply With Quote
Old 02-23-2008, 06:22 PM   #2
the_experience03's Avatar
Re: transit bus frames
Typically they are made of stainless steel welded together in 5 foot sections. I have heard both good and bad about this. On the side of good it is stainless steel. This doesn't mean it won't rust, but it sure does help in the fight against corrosion. On the bad side of things is that the metaleurgy of stainless is not the best for a frame application, nor is the idea of welded sections. I suppose a person could replace a section of their frame easily enough in that it was assembled in sections, but then you're welding stainless, something that exceeds the capabilities of most people, myself included.
Is this transit bus a good idea? djDK Conversion General Discussions 33 03-22-2017 02:48 PM
BOW FRAMES dogfinn Skoolie Conversion Projects 9 05-25-2010 03:36 PM
Welding Storage Boxes, Tank Frames elkoskoolie Conversion General Discussions 6 05-10-2010 09:05 PM
new uses for old seat frames... NewSkewlHauler Conversion General Discussions 2 01-03-2010 12:38 PM
How's This Transit Bus? runnysucklehose Conversion General Discussions 9 02-15-2006 08:24 PM
